Buying Advice Advice on 5065M or 5075M
/ Advice on 5065M or 5075M #1
boydeere
va
6320 jd 2510 jd 530 jd
Need second tractor to load manure, and rake and ted hay. Are these good used tractors?
Thanks.
Thanks.
Evidentially no one on here owns one of these!
/ Advice on 5065M or 5075M #3
How big is your operation? A 5000 series might be just right for you but it would be just a guess for us. Around my area they usually use a heaver framed tractor. Some of the bigger guys use a 7000 series for a loader tractor.
/ Advice on 5065M or 5075M #4
There are several 50xxM tractor owners on this site. Surprised you haven't received more response.
I haven't owned one but there are a LOT of them around me. I've not heard any complaints. Either will easily handle the chores you listed.
What are you going to have to pay for a used one??
300 acres hay ground three times per year. Around 150 tons of poultry litter to load and around 300 tons of cattle manure to load/year
Looks like around $30k if I can find a good used one
/ Advice on 5065M or 5075M #7
A 5 series can handle that.
/ Advice on 5065M or 5075M #9
I watched an older 5310 moving large round bales Sunday. It's considerably smaller/lighter than the current 5 series. He was carrying 2 at a time, one on the FEL, one on a rear stabber and easily loaded a GN tandem axle deckover trailer 2 bales high.
The JD guys must all be in the fields trying to put up hay today!!! I'm watching it rain all day in Missouri. :)
That's one thing I like about the M series. They are heavier than the E series. Having used FEL's all my life, you need the weight when moving bales and loading wet heavy manure.
/ Advice on 5065M or 5075M #11
Yes. No flame intended. But I never even considered an E model when looking at JD. I really had my heart set on an M JD but the cost difference to my Kubota M was something I just couldn't deal with.
Beyond the weight, all the comfort and ease of use features separates them beyond compare.
Good luck with whatever you choose. Of course you gotta post pictures and let us know how it turns out. :)
/ Advice on 5065M or 5075M #12
I have a 5520which is probably 85 hp. With two weights on each side of the rears and a front weight starter bracket (285 lbs) it handles anything I can lift. It has radials, so that adds some weight but I really like the tractor. My neighbor has a Kubota M7040 with a loader and it is light and bounces all around.
/ Advice on 5065M or 5075M #13
I have a 2011 5085m. With 553 loader. It has been great. For your task the 5065 or 5075m will have no problem. No where could I find another brand of tractor from 60-80 hp power with the weight and also the comfort of these units. Good luck. I have heard the 5cylinder engine in these units are also a beast.
/ Advice on 5065M or 5075M #14
Yep. JD tractors are considerably heavier than Kubotas in like HP ranges. For what I do, I like that. For what the OP is wanting to do he will appreciate the chassis weight.
I've got an older Ford 3910 FWD (47hp) tractor without FEL. I used it the other day to stack large round bales with a 3pt carrier and no front weights. It handled the job fine. No way a Kubota in that HP range would have. Chassis weight is your friend when doing almost any AG related task.
Popsie has the tractor I looked hard at before buying my Kubota. :)
/ Advice on 5065M or 5075M #15
Is your Ford 3910 the one you did the front bush axle bushing on?
/ Advice on 5065M or 5075M #16
/ Advice on 5065M or 5075M #17
Yep. Worked out fine. No leaks. Miracle!!! :)
What a wonderful tractor and great job you did on it. I'd like to find one.
/ Advice on 5065M or 5075M #18
It wasn't skill on my part, pure luck.
The more I use it, the more I realize it's value. It has features my 2011 Kubota doesn't have. It has a hand operated park brake that locks the front drive as well as the rear, regardless of whether it's in 4wd. It has a "fast" or "slow" setting for the hydraulics that also changes the speed of the 3pt. Additionally it has fast/slow settings on both rear hydraulic outlets. It's very well balanced. Very capable for it's size. Only drawback I've found is it doesn't turn as short as my Kubota.
Sorry to the OP for the Hijack.... :(
No problem. Just glad someone responded.
/ Advice on 5065M or 5075M #20
I'm disappointed as well. Usually a JD discussion blooms into something large. Everybody must be busy.
Let us know what you decide. And if you purchase, please post pictures. :)
