JD 5603 OIL IN RADIATOR
   / JD 5603 OIL IN RADIATOR #1
srqtech
Sarasota FL
JD 5603, 6815 , Kubota L5740
We have A John Deere 5603 and upon checking the oil this past Friday found it to be 4 1/2 qts low. Filled it, blamed the operator for not checking the oil and sent it out . A couple hours later it was running hot. found oil in the cooling system. I suspect maybe engine oil cooler seals leaking but haven't made it to that part of my research. Any one have any thoughts or experienced this ?
   / JD 5603 OIL IN RADIATOR #2
About 30 years ago we had a Massey Fergerson tractor with a Perkins V-8 engine. We were having the same problem with getting oil in the water.
It turned out to be warped heads. We had to remove the heads and get them shaved. Then it happened again and we ended up changing the heads.
Hope this is not your problem, but it's something to consider.
   / JD 5603 OIL IN RADIATOR #3
You have a cylinder head problem.
You could try re torquing it when hot but I think at a minimum you are going to need a new head gasket and the head should be checked by a machine shop.
Rad will need professional cleaning to get the oil out.
Dave M7040
   / JD 5603 OIL IN RADIATOR #4
Dave M7040
This.
The bad part is it will only get worse, and more expensive, if you don't do something about it now. Hopefully it's just a failed head gasket and the head hasn't warped yet, but there's only one way to know.
   / JD 5603 OIL IN RADIATOR #5
srqtech
I agree that engine oil cooler is the place to start diagnostics.
I haven't found in the manual that it has an engine oil cooler, only hydraulic oil cooler and that's external in front of the radiator. I have A feeling the heads coming off !
   / JD 5603 OIL IN RADIATOR #7
My neighbors 5603 had a leaking engine oil cooler. They resemble this parts photo.
Thanks so much. I located where its at and Ill be pulling it tomorrow. Easier than pulling the top end , hopefully that's as far as I need to go.
   / JD 5603 OIL IN RADIATOR #9
drain radiator and fill with water add cascade dish washing detergant and get it hot then flush several times and radiator will be good as new
Update, removed the cooler and took it to our local radiator shop. Held 50 lbs. with no leaks. Didn't want that outcome ! I guess its head time !
2023 Ford F-150 4x4 Crew Cab Pickup Truck (A55788)
2023 Ford F-150...
2015 Ford Escape SUV (A55758)
2015 Ford Escape...
ASSORTED NYLON SLINGS (A54757)
ASSORTED NYLON...
2017 CASE IH 580 QUADTRAC ARTICULATING TRACTOR (A52705)
2017 CASE IH 580...
2012 Ram 3500 Crew Cab Flat Bed Truck (A55788)
2012 Ram 3500 Crew...
2019 CATERPILLAR 926M WHEEL LOADER (A52705)
2019 CATERPILLAR...
