motorhome convert to pickup
/ motorhome convert to pickup
I got problems
the frame is NOT box... it is U shaped. I couldn't tell before because the sheet metal covering it.
Now that I got the sub frame off and I can see under the sheet metal
some places there is a 1/4" thick top plate welded on
and in other places there is a diagonal plate inside the u but not all in the same places
and in some places the u frame is doubled up
here is a drawing I got pics comming later when I get my cell phone back.
please someone tell me what to do??
is this some sort of unified frame/body???
wtf
I think my hauler dreams just went out in the friggin garbage!!!
/ motorhome convert to pickup #103
Nothing wrong with a C Channel frame. Most trucks use this type frame.
I have a 49 Chevy 1 1/2 Ton that has C Channel frame. It was originally a fire tanker truck. That C Channel frame hauled a 1000 gallon water tank on it. It was a cab n chassis when I bought it. I had a 10'6" x 8' flatbed built for it and I installed 2 x 10 hemlock deck. Made the rear bumper with trailer hitch also. I thought about mounting a goose neck hitch but I don't have a GN trailer anymore and the truck spends more time going to car shows than hauling anyway.
no, this is NOT a c channel frame.
this is not a box frame.
It is a U as in the letter U shaped frame!
It is a unibody
that means I cant haul **** with it.
I could haul a lawn mower trailer and that is about the max...
project over
not even worth pulling the engine or tranny out of it.
I am calling the scap guy tomorrow to come get it!!!
SAW - "GAME OVER"
I lose..
/ motorhome convert to pickup #106
Steve,
from the pics you posted (attached) where the spring perches are mounted on 1 pic and the frame on each side of the spare tire in the second sure look like a C channel frame to me.
/ motorhome convert to pickup #107
Sounds like he found some fish plates from where it was stretched.
We need more pics. You can't be this high strung getting into a project like this. You've gotta roll with what you uncover.
yeah I am rolling with it... rolling with it right to the scrap yard.
the whole frame is u channel except the very front frame suspention area is boxed and it is bolted on..
I should have crawled under it before I started.
just not worth bothering with
/ motorhome convert to pickup #109
I don't know why you are scrapping this project? The frame you have was heavy enough to support a rv and all it's supporting equipment, why would it not be heavy enough to haul what you want with it? I am assuming the flat bed you would have fabricated would have strengthened the vehicle even more.
Your frame is just like a C-channel turned up and enclosed on top. It's essentially a boxed tube, should be strong enough. It was strong enough to require a dually axle in the rear.
/ motorhome convert to pickup #110
Does it run right now? Like can it be driven if there was lights on the back and licensed?
2021 Ford F-250 4x4 Crew Cab Pickup Truck (A59230)
2021 Ford F-250...
iDrive TDS-2010H...
2006 INTERNATIONAL 7400 6X4 DUMP TRUCK (A52706)
2006 INTERNATIONAL...
2019 ALLMAND LIGHT PLANT (A60736)
2019 ALLMAND LIGHT...
2019 Chevrolet Silverado 6500HD 4x4 ETI ETC37IH 37FT Insulated Bucket Truck (A59230)
2019 Chevrolet...
2024 Kubota M7-174D (Deluxe) 4WD Tractor - 244 Hours (A61307)
2024 Kubota...
