T353 electrical problem (long description) NEED HELP
/ T353 electrical problem (long description) NEED HELP #1
Jon E
Member
Southwestern Vermont (on the NYS line)
2014 TYM T353HST
Boy this one has me stumped. Started yesterday by getting on the tractor, started up immediately, ran it for close to 45 minutes, shut it down a couple of times while I was off the machine, but started right back up again within five minutes or so. I am not a big fan of letting the machine idle for more than a few minutes unless it's cold out. Anyway, I switched from bucket to pallet forks, put a pallet on the forks and drove it up to the house as I was going to load a bunch of totes on the pallet and bring them to my shed. Tractor was off for maybe 3-4 hours. When I went back out to start it again, I got on it, gear in neutral, held in the parking brake (just like EVERY other time I start the machine). The machine tried to turn over for about five seconds and then just stopped. Nothing. I turned the key again and nothing. Jiggled the pedals, moved the transmission lever (is a hydro model), turned everything off and back on again, nothing.
Opened the hood, checked the battery, 12.63 volts across terminals. When I turn the key, I can hear the fuel pump, the glow plugs "clicking", all the lights are working (4-ways, headlights, etc.) Electrical system appears to be getting full battery power.
Checked the starter, 12.39 volts at the starter, "jumped" the starter with a screwdriver (I know I shouldn't do that but HEY I gotta try everything), the starter spun & the machine tried to turn over again. Probably could have got it running if I wanted to weld a screwdriver to the starter terminals, but I'm not that stupid AND it wouldn't have solved my problem. Checked every fuse in the fuse box, all good. Checked every other fuse I could find, all good. Took the dash apart, checked the brake pedal safety switch, seemed to be working fine, not sure how to TEST it, but I can't imagine that's the problem.
So I have ruled out the following: battery, starter motor, fuses, brake safety switch, key switch, electrical wiring from battery to starter. The machine does not appear to HAVE a seat dead-man switch. I can't find any wires going to the seat and the machine does not shut off no matter when I leave the seat. So I don't think that's a problem either. The thing that struck me as odd is that it shut off in the middle of trying to start. Like the power to the starter was cut suddenly - or a fuse or relay blew.
So what do I try next? The dealer has been OK, not great but not particularly helpful. In this case, I called and was told that I should try to figure out the problem myself and if I was unsuccessful, call in the morning. Well, I'm unsuccessful but hoping someone here might be able to help...
/ T353 electrical problem (long description) NEED HELP #2
Measure the voltage on starter solenoid when key is in starting position. You might need a helper to do so. In lack of helper put a light parallel to the solenoid. If light turns on when trying to start then the solenoid is bad or has bad connection. You can also measure the resistance of the solenoid against ground. It should be several ohms ( 10 ohm plus minus) I think. If the solenoid pulls but the tractor doesn't start the solenoid contact is bad or the screws holding the contacts are lose. Some solenoid can be taken apart some has to be replaced a unit. If there is no voltage on the solenoid then it is possible that the control unit is faulty. Call the dealer and ask for testing diagram. Attached is testing diagram for TYM 330. The control units might might be the same. If not then the dealer has the correct diagram for your tractor.
CCF07182013_00000.jpg CCF07182013_00001.jpg CCF07182013_00002.jpg CCF07182013_00003.jpg CCF07182013_00004.jpg CCF07182013_00005.jpg CCF07182013_00006.jpg
/ T353 electrical problem (long description) NEED HELP #4
Had a problem about like that on my 273. Turned out to be a 40 amp fuse that is taped to the wiring harness under the dash. It blew because of chafed wiring.
/ T353 electrical problem (long description) NEED HELP #5
Bet there is a fusible link somewhere in the electrical system that blew....
/ T353 electrical problem (long description) NEED HELP #6
any idea how to diagnose 353 Cruise Control --- it will not work for first 30-45 minutes ---then it's ok..........heats up somthing ?
any help would be great --- problem for about 6 months now on 6 year old 353HST --- had it fixed after 2.5 years -- closest dealer is 100 miles away NOW.....
thanks,
bob
/ T353 electrical problem (long description) NEED HELP #7
thanks,
bob
The cruise control is quite simple. There is an electromagnet that "freezes" the go forward pedal. I don't know from top of my head if there is a relay or if the magnet is operated directly by the switch. It might be bad connection somewhere or the gap between the magnet and the pedal is to big.
/ T353 electrical problem (long description) NEED HELP #8
the switch goes to a relay then the control module then the magnet..the Switch light does not light up for 30-45 minutes so the circuit is not compleate. the relay is 30-40 dollars and the module is 300 dollars---don't like replacing parts trying to find problem......
thx bob
2019 INTERNATIONAL DURASTAR 4300 REEFER BOX TRUCK (A60736)
2019 INTERNATIONAL...
2012 KINZE FLAT FOLD ROW MARKERS SET FOR 12 ROW 36/38 STACK FOLD TOOL BAR (A55315)
2012 KINZE FLAT...
Water/Sewer Milwaukee Tap Machine (A61166)
Water/Sewer...
2025 Polaris Ranger Premium (A60462)
2025 Polaris...
2000 Bobcat 863 High Flow Compact Wheel Loader Skid Steer (A59228)
2000 Bobcat 863...
2019 Ford F450 4x4 Service Truck w/ Tommy Gate (A62613)
2019 Ford F450 4x4...
