Good morning!!!!
   / Good morning!!!! #36,672
Wouldnt it be nice if a new faucet came with that little tube of silicone caulk that you need to install it.....
Good evening, called for rain but got none. could use a little.
   / Good morning!!!! #36,673
So you are limited to the morning?
I can be an under achiever all day or weekend long.
Don't limit yourself, stretch out procrastination to the point of spousal rebellion.
You'll save thousands of hours of busy work that won't be appreciated anywhere near as much as getting a job done just before she blows with a few well placed hours done just in time.
Morning underachievers is open to all in the "Good Morning thread" not morning time specifically. So yes thousands of work hours will not be unappreciated - because they didn't happen.:thumbsup:
   / Good morning!!!! #36,674
A fine and breezy morning, it should be just right for haymaking today, at a field about a mile away that goes all the way around a private airfield. It is a tiny airstrip, only used by a few keen flyers. No doubt the talk will be all about the accident at the nearby Oulton Park airshow last week, which killed the pilot of an historic Folland Gnat jet. I have never been to an airshow and don't really need to as they often fly right by our house, but they do seem to be highly risky events. Makes me wonder if the danger is a major part of the attraction to both pilots and spectators.
Hey, you have Planes, Trains, and Automobiles!
   / Good morning!!!! #36,675
Not sure if that was plain bad cooking, or you were experiencing part of the charm of the Welsh - a gift some have for of subtly demonstrating that deep down, quite a few hate anyone who isn't also Welsh. :)
Pretty sure I experienced that later on the same trip when I pulled into a gas station with an urgent need to relieve myself (that breakfast tea really went right through me :laughing:). The attendant showed his courtesy by denying me the key even though I assured him I would be buying a tank of gas. I repaid the favor by walking around to the door of the loo, making a mess on the concrete (I did say URGENT), and purchasing fuel a bit farther down the road.:thumbsdown:
   / Good morning!!!! #36,677
That's good to hear. You're doing everything you can to get it back to snuff I suppose?
I'm not sure what I can do to get it back to snuff...I'm trying not to stub it again
2015-08-11, 0324
68 right now. Not going to get much warmer...looks like a high of 70 today and a high probability of thunderstorms.
   / Good morning!!!! #36,678
71.3F and overcast @ 03:00 ...
The heavy, slow-moving thunderstorms in the forecast turned out to be a bust ... petered out just before they got here ... which is unfortunate, because it's been awhile since we've had any rain. I noticed yesterday that the (undisturbed) ground around some hawthorn trees next to where I was transplanting was actually cracked pretty bad. The grass has gone into summer dormancy ... not because it's been all that hot - it hasn't - just due to lack of precipitation I guess.
Speaking of transplanting, we've managed to transplant 1 (smaller) japanese yew, 3 clumps of pampas grass, and 7 oak trees - which ranged in height from around 5' or 6' up to 12'. The oaks seem to be doing well, with only a little bit of leaf loss on a couple that we couldn't get in the ground immediately after digging them (cluster of 3 trees) ... but I've been watering them every couple of days ... usually about 20 to 25 gallons per tree. Still need to mulch around the base of the trees to slow moisture loss.
437266-good-morning-img_2260-jpg
437267-good-morning-img_2259-jpg
Between the recent transplants and existing shrubs, I've probably have hauled 750 gallons of water or more at this point, just in the last week or so.
I spent Saturday afternoon and evening pumping out and pulling the 275 gallon fuel oil tank. Wound up with about 130 gallons of fuel ... which will probably cover me until next summer. Getting the tank up out of the basement was a PITA - 90 degree turn on the landing at the top of the steps to get out the door ... but a friend and I managed it. Tank appears to be sound and relatively decent shape ... no obvious leaks, just some surface rust on the backside where it was close to the basement wall.
Today I got around 10 pallets of stuff moved back into the polebarn in anticipation of the rain that never really happened. After that I dug about 15' of trench for the downspout drain, got the first 10' section of pipe laid and connected to the downspout, cleaned out the section of gutter that that downspout drains, and nailed the gutter back in wherever it was loose.
I had to dig out around the foundation where the downspout comes down in order to repair it (the foundation) ... the downspout was missing the bottom section that redirected the water away from the foundation and it has been dumping water next to the foundation. With the winter freeze and thaw cycles some of the bricks had come loose and several blocks were damaged:
437263-good-morning-img_2265-jpg
Figure I'll just lay a piece of plywood in there for a form and fill it with 'crete ... after I hose down and clean off the block.
As part of this project I did some work on this monster, just to gain access to the foundation to be able to work on it, which involved trimming out some of the understory:
437264-good-morning-img_2262-jpg
Originally, the idea was to remove the entire plant and transplant it elsewhere. After messing with transplanting the oak trees, and getting a good look at the main trunk of this rhody, I've decided that I'm not going to do that - it's just too big.
What I found in doing the trimming was that a lot of the drooping branches had begun to root wherever they touched the soil and were covered with leaves:
437265-good-morning-img_2268-jpg
So I went ahead and made a cut with a razor knife between the rooting part of the stems and the main plant to cause further rooting, pinned down the stems with cut coat hangers, and covered the section that was beginning to root with compost and then mulched over it. In another month and a half, I'll cut the stems going back to the main plant and hopefully by next spring I'll have 18 to 24 more individual rhododendrons ready to transplant. This specimen has light purple blooms ... so it should add some color around the place.
So in addition to removing the propagated portions around the perimeter, I'll probably just trim the upper part - to try and get it under control and away from the electric lines coming from the transformer on the power pole.
Met last Friday with a realtor on the commercial property. As of today they will have the listing. Be interesting to see what kind of interest they get on it.
Hope everyone has an enjoyable and productive day.
   / Good morning!!!! #36,679
Should be fine again today for haymaking. I lost a few tines on the haybob yesterday. To try and save my hearing, I now wear ear plugs when I do hours of pto work, but that meant I didn't hear a thing when the tines broke, so I need to be more careful today.
My grandmother was from England, and she cooked all meat very, very well done. Her hamburger's would actually crunch when you ate them!
I also tend to like meat well done (but not crunchy hamburgers !). Not sure if that's because that was how it was served up when I was young, or I just have an inherent aversion to tape worms and liver fluke. Now if the vet would only give me wormer pills like he does the dog, I could enjoy meat with blood oozing out too. ;)
I'm with you vts, but have you any tips on how to do it ? Anyone can simply put things off for another day, but it takes real skill to actually persuade your wife, or yourself, that it's actually better to do it tomorrow than today.
A few years back I was getting worried that my previously unlimited supply of plausible excuses was running low, then came the aging body and now I'm finding a whole new set to go at, it's a revelation. :)
   / Good morning!!!! #36,680
2015-08-11, 0324
68 right now. Now going to get much warmer...looks like a high of 70 today and a high probability of thunderstorms.
Well I'm not a doctor but I hear there is this thing that improves circulation without any negative side effects. I believe it is called "exercise" or some other foreign term. Ain't never tried it myself except by accident.:rolleyes:
2016 WITZCO RG-35 RGN LOWBOY TRAILER (A51243)
2016 WITZCO RG-35...
IF YOU BID ON AN ITEM YOU MUST PAY FOR IT!! NO BACKING OUT AFTER IT IS SOLD!! (A50775)
IF YOU BID ON AN...
CAT 938B 2 Wheel Loader (A47384)
CAT 938B 2 Wheel...
2023 TAKE 3 TRAILER 3 CAR TRAILER (A52141)
2023 TAKE 3...
Quick Attach Accumulator Grapple (A50514)
Quick Attach...
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
