blade bolt
/ blade bolt #1
rangerrick180
griffin ga.
ym 180
hi folks , i am trying to replace blades on a 5x5 sidewinder fmc rotary mower.
i have got the nuts off of the top side but cant get the bottom of the
bolt to brake loose. my question is does the part that the blade bolt
goes thru have threads also. i replaced some on a bushhog brand mower
one time and it didnt have threads in that part ? any info or advise
would be appreciated!
/ blade bolt #2
If you will go to the link, I think the picture will show you what you are dealing with. The bushing doesn't appear to have threads, just looks like it is pressed in maybe? Be sure to double click on the image.
You might try putting the nut back on the threads so it's flush with the bolt, the tap on it with a mallet, or maybe cover it with a piece of wood and bang on it a few times. It wouldn't hurt to hose it down with some penetrating fluid first. Good luck.
Sidewinder Blade Bolt
/ blade bolt #4
Not sure on that particular cutter, but there is usually a small key in the bolt to keep the bolt head from spinning when you tighten the nut. IF that is indeed the case, you aint gonna get the bottom to spin.
You have to drive the bolts out from the top.
Either put the nut back on and use a wood block, or a punch right in the middle of the bolt. The bolts I buy are recessed on the top end and fit a 3/8" punch pretty good.
/ blade bolt #5
Thank you,
I am currently taking my FMC Side Winder pull behind cutter apart to replace the blades. A lot of banging and hitting and oils and brake fluid. At first unsupported and putting on the pressure on the gear box. Then supported with nothing happening. After seeing this post, I then bought at 1000ftlb impact wrench and hit each one of them. I figured since the bolt was threaded maybe the rust was threaded and it would spin easier than being beaten out.
WELL. Turns out the the bolts are threaded into the inch thick bar and the bolt on top acts more like a locking nut.
One came off with the new impact drive while the other one is still giving me a headache. It will be a couple of more days of oils and heat and impact before it comes off.
Thanks to everyone that posted but I just wanted to let people know that sometimes they are threaded into the center bar. (and if the nut on the top comes off correctly, then it is not reverse thread)
2017 Ford Fusion SE Hybrid Sedan (A61574)
2017 Ford Fusion...
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A63569)
2020 TROXELL...
2016 International Workstar 7500 T/A Dump Truck (A61573)
2016 International...
208315 (A58376)
208315 (A58376)
(INOP) 2013 MACK ELITE LEU633 GARBAGE TRUCK (A62130)
(INOP) 2013 MACK...
CASE INTERNATIONAL 5240 TRACTOR (A63291)
CASE INTERNATIONAL...
