Clevis or hammerstrap for drawbar on M7040
   / Clevis or hammerstrap for drawbar on M7040
The drawbar will only be weakened by a weld across it. That is also why to never weld across a car/truck/trailer frame...like when installing or repairing leaf springs.
The user will have to evaluate how to deal with such a drawbar and the circumstance under which it will be used.
Actually, my preferred way to hook up clevis-style implements or trailers is by using a cross drawbar across the lower lift arms of the 3PH. They come in Cat 1 or Cat 2.
CountyLine Cross Drawbar, Category 0 with Category 1 Pins | TractorSupply
Good way to flip a tractor over if you don't know what you're doing and raise up the 3 point above the axle centerline. Of course you could get the lock that manufacturers suggest but no on installs. These are good for small Hp and low load.
   / Clevis or hammerstrap for drawbar on M7040 #22
They have no down pressure, so can jump up & upset your center of gravity in many situations like braking when going downhill.
I use a 3pt to 2" receiver adapter to move my various trailers around. But I'm always cautious & on pretty level ground. I wouldn't use it on rough ground, steep ground, or on a road or anywhere i would have to stop suddenly. But it works for a few hundred yards on easy ground around the house.
2012 John Deere 9560RT Track Tractor (A50657)
2012 John Deere...
2 Vintage Metal Signs (A48081)
2 Vintage Metal...
2019 MMDI 14ft T/A Utility Trailer w/ Fuel Tank (A48082)
2019 MMDI 14ft T/A...
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
AC CHARGING MACHINE (A50854)
AC CHARGING...
WITTIG VACUUM PUMP (A50854)
WITTIG VACUUM PUMP...
