Off-Grid Solar Setups
/ Off-Grid Solar Setups #21
We purchased 32 acres 2 years ago & would *like* to start building. While I'm still figuring out the house logistics (could that be another thread?) as to whether or not to build with SIPs or another method, I've run into an issue with getting electricity to the house. Our utility company in NY is National Grid and they've tentatively given me a $25k number for running electrical from the road, 1300 feet to where we'll put the house. They won't give me a FIRM number until I have some sort of structure built on the property (which seems kinda ***-backwards to me).
With Federal, State & Local rebates I was wondering about going off grid completely with a battery system. My initial findings was that the batteries weren't even lasting 10 years, which made the setup very cost-prohibitive if I had to replace the batteries every 7 years or so. The Tesla Power Wall came out & they guarantee nothing more than 8% loss at 10 years, which would *seem* to me to mean that it should last longer.
Our current temporary house is 120 years old and we use 13,000 kwh per year or 1083 kwh per month. But that's on an OLD home with very little insulation, etc. We're hoping to build with SIPs or closed cell spray foam at the very least, so figuring that along with LED lights energy efficient appliances, a propane stove and dryer, it should all add up to considerably less usage. I'm also looking at hydronic radiant floor heating. Cooling is my biggest concern, though in CNY, we're talking all of 3-4 months and it's not run constantly.
Thoughts, issues, concerns? Anyone already doing this or looking into this?
Here's our land in case anyone is curious...the black outline is ours. I don't have a current areal picture of the driveway we put in last year, sorry!
Seems like you should get yourself a good tractor and backhoe and dig the ditch yourself, put the conduit and pull boxes in to their specs and just have them pull the wire. I did this on my house, but it was only 220' from the pole. You'll save enough to pay for the tractor. I also bought an off-road forklift for the project and it too has paid for itself over and over. Then it will move on to another project somewhere, but my tractor stays!
By all means add hydronic radiant in your slab!!! But drive it with thermal solar. Very low cost of operation, also does domestic hot water and there is no heating system more comfortable. Last winter we used three 70 watt circulators, running during the day, to heat our 2,800 sq ft house through the winter. No energy source other than solar. But I also have a wood stove in case we want an evening fire or to take the chill off a surprise cool morning. Now, in the spring, summer and fall months, we have 650 gallons of domestic hot water on tap for occasional bathroom floor heat and unlimited showers. I can't imagine a cheaper or more comfortable heating system! Then, if you need to, you could add a simple air conditioning system that is entirely separate from your heating system. I added a simple duct system and wired the house for air conditioning, but I doubt I'll ever install it.
My priorities in the house design included a steel frame, but most of the structure is 2/6 and 2/8 walls with blown in insulation and blown in attic insulation. Not the absolute lowest heat loss, but totally practical and a structure that is incredibly strong.
I don't like propane, so I only put it in for cooking with the rangetop. I installed a cast iron boiler that runs on oil for backup if needed. Then I modified it to be more efficient than originally designed. We also have an electric water heater that remains permanently switched off unless the solar is shut down for more than about three days or in the event of severe winter conditions for an extended period. In the end, the cost of heating is insignificant
Be sure to include practicality in your design considerations. For instance, you might sacrifice a bit of theoretical R value for much simpler construction or lower cost or stronger structure. R value is only one of many considerations
/ Off-Grid Solar Setups #22
We have 100% electric house but because our PV can't be "islanded" when power grid goes down we have two propane fireplaces for heat backup.
Do you have any battery or just use the grid for backup electicity now?[/QUOTE]
We are Grid Tie.
We installed Enphase inverters that are grid commutated. In other words when grid goes down they disconnect. When grid comes back ON they wait 5 minutes before they reconnect.
The reason for selecting microinverters was DIY solar installation without previous experience. When the panels are illuminated they are ON and more or less impossible to switch off. I didn't want take risk of shorting something and burn the cables or got killed by high voltage. Then I learned during actual installation that it was irrational fear. Installation of PV is pretty straightforward. If you are able to install an outlet or change a breaker you should be able to install PV. 95% if installation is plug in and the rest is simple wiring. If I would do it again I would use "island-able" inverter.
I am thinking about energy storage but so far can't find a controller that would manage it the way I want to. My idea is to manage it such a way that my system will supply energy to the grid only when all energy storage is full and prevent charging of energy storage from grid when sun is not shining. Then allow import of energy from grid only after energy storage system(s) are depleted.
As I already said elsewhere in this and "Grid-Tie" thread our utility doesn't offer net metering at all. In addition the utility cancelled our heating rate after installation of PV essentially increasing our electric bill by 500-600 USD a year. The result is that we generate about 30% more energy that we use and we still have, though low, electric bill. When I initially talked to them about the PV installation they sent me pamphlet describing net metering. But after we installed the PV they backpedaled saying that, because of the size of the system, we are industrial generators and net metering will not apply.
Therefore it is very important to have connection agreement detailed and signed before you spend money for the hardware and installation.
Still I don't want it to look like I am complaining (though I am rather disappointed how I was treated by the utility). We used the tax rebate as down payment for few duplexes bought for distressed price that we sold year later with very good profit making our system paid for itself. You can get lucky sometimes I suppose. I was asked by many people if the system is profitable. I respond with a question if their 50K truck or Porsche is profitable or how much their CD in a bank brinks in. There are many ways to look at investment in alternative energy systems.
If you can include solar in the mortgage it is no brainer. If you get net metering on top of it it is an investment that is hard to beat. That is MHO.
Ladia
/ Off-Grid Solar Setups #23
I'm interested in reducing the draw so a battery system could get through the night. Example; Say I take a shower at night, I'd like the hot water heater to delay recovery until PV system is working to cover recovery rather that tax battery all night while it's running AC or heat? Same with a well pump, no need to fill cistron at night under battery. How can all that be managed. HS
That is very easy to accomplish with a timer with battery backup and contactor . If you want to get fancy then buy a PLC for about 100 USD on ebay. You need to (preferably) select one that has real time clock with battery backup or have external timer that will reset the PLC timer once a day sync it in the case power goes down.
https://www.google.com/webhp?source...n=1&espv=2&ie=UTF-8#q=30a contactor 120v coil
Amazon.com: Hydrofarm TM01715D 7-Day Digital Program Timer: Patio, Lawn & Garden
/ Off-Grid Solar Setups #24
For heating, we're LOOKING at going strictly with hydroponic radiant floor (no HVAC) - it's a solar based system and would be really efficient.
....but that leaves me with how we cool the house for the relative little we need to in the summer.
Instead installing passive solar invest the money in more PV and heat/chill liquid for heating and forced air AC. I just read an article while ago about PV versus passive solar and the numbers showed PV was cheaper than passive collectors and associated heat storage. Since you are in TX you have, presumably, many more AC days than heating days. Here is a link to a heat pump that would do both: Small Heat Pump Chillers | Chiller Air Conditioner For Home or Office | Residential Ductless Mini Split Chillers If you have only small number of heating days I wouldn't spend money on floor heating but rather increase size of PV. If you would be grid tie with net metering then I would use mini split units. They are cheap, easy to install and replace, quiet, very efficient and every room has its own independent temperature control.
We have geothermal HP with floor heating/ forced air AC in our current house but if I would do it again I would do mini splits. We have one unit with two indoor handlers in my shop office and guest room and I like them better than geo. Not speaking about the cost of the geo plus floor heating and forced air. Geo costs at least three time as much as mini splits even though we did a kot of the work DIY.
What's the difference between passive solar and PV?
/ Off-Grid Solar Setups #26
We have geothermal HP with floor heating/ forced air AC in our current house but if I would do it again I would do mini splits. We have one unit with two indoor handlers in my shop office and guest room and I like them better than geo. Not speaking about the cost of the geo plus floor heating and forced air. Geo costs at least three time as much as mini splits even though we did a kot of the work DIY.[/QUOTE
I agree with you on this point - We have a very low cost for our GSHP and it works well but I also have 2 mini-split units (for ares that duct work was difficult to get to) and would much rather have $18,000 of PV on my roof along with a couple more mini-split units: Put out warmer air in heating mode and worked this winter at -5' F, able to control each area independently, have back up if a unit breaks down, lower peak load than my GSHP along with well to pump water.
DIY PV is very quick pay back (our electricty is ~ $0.13/kwh) - looking into adding it to current house but most likely will wait and install during the build of next house.
How large of a system do you have that triggered the "industrial generator" interpretation? around here I think it is 15KW
/ Off-Grid Solar Setups #27
This is how I would define solar categories. The distinctions are a bit fuzzy.
I wouldn't consider either of these to be "passive."
solar thermal: collect sunshine heat and transfer it to a medium such as water or glycol. This can be quite "passive" in a thermo-siphon or batch heater tank system but there are usually some active controls involved.
solar electric (pv): generate electricity from sunshine.
direct gain passive solar space heating: heating interior space with sunshine coming through windows. The gained heat is generally absorbed by a thermal mass such as concrete. It works based on thermodynamics: heat moves from a warm object to a cooler object. Warm air to cooler concrete on sunny days, and warmer concrete to cooler air overnight.
indirect gain passive solar space heating: heating a storage medium (salt, glycol, rock, Trombe wall, etc.) that then radiates that heat into the interior space.
active solar space heating: a good example would be a radiant floor heat system using solar thermal collectors as the heat source.
/ Off-Grid Solar Setups #28
The term passive solar was misused in one of the previous posts. Passive is just building orientation, overhang design and window sizing to "passively" catch the sun seasonally and store some of that in exposed concrete or other mass in the house. No moving parts. PV is electric solar generating that stands for photovoltaic. Active solar is water heating where a liquid is pumped through the collectors. It gets warm and is stored for later use in radiant heating or domestic hot water systems. Geothermal gathers heat from warm earth below ground level and uses a heat pump to deliver useful energy to the house. It's kind of a backwards refrigerator that sends it's "waste" heat to the house for heating.
Comparing mini split systems to in-slab radiant and discussing only the cost is misleading. Radiant heat is the most comfortable and quietest delivery system there is and it can easily be zoned with as many thermostats as wanted. Whereas a mini split does nothing for warming floors, makes more noise and takes up space in each of it's zones. It is better suited to homes with carpeting, ones being retro-fitted or when adding air conditioning. Geothermal is OK, but scares me with its enormous requirement for ground collecting and it's complicated and expensive equipment. My neighbors put it in their house and I did the radiant. Then the Geo contractor connected the two. They have an extremely efficient home with some passive solar and domestic hot water solar too. But they still pay about $350./month, in the winter for electricity and they have had to replace the heat pump once in only about 5 years. Overall it would have been cheaper to just heat with propane, and much simpler and less expensive to install.
As I mentioned earlier, I think the benefits of active solar for radiant heating, and a simple air conditioning system, if really needed, is the way to go for heating and cooling. If someone wants to build their own system, it's an excellent match because it's somewhat labor intensive, but simple in it's application. And it has all low tech equipment that is easily serviced if needed.
/ Off-Grid Solar Setups #29
This was designed as a passive solar house. There is a central atrium and stairwell to circulate air. There is a tile floor over slab. Orientation is south. On a sunny day the house will stay at 70 until temps are below freezing.
In lower temps the house is heated by baseboards, a Rinnai wall heater, or a Hearthstone wood stove.
/ Off-Grid Solar Setups #30
Another approach to cutting a house's energy footprint is earth berming. A house with thick brick walls, earth berms, or one that is sealed to Passive Haus standards has virtually no air infiltration through the walls. That is as important as the R-value of the wall. Besides cutting air infiltration to zero, earth berms replace ambient outdoor air temperatures with ground temperatures. Ground temps in winter can be 50-60 degrees warmer than air temps in northern climates. Preventing frost penetration into the ground near the foundation is accomplished with 2-4 inches of Styrofoam sheets laid out as a apron surrounding the exterior walls--very much like a shallow frost-protected foundation is done. That can be combined with ICF walls or by using foam on the exterior of a poured concrete wall. The end result is no air infiltration, reasonable R-values for exterior walls, and a very low delta between the exterior and interior temperatures which means the rate of heat exchange between them will be very low.
Dave speaks truth. Like he said, plan to use passive solar. Build your house with an overhang that shades from the sun in the summer but allows sun in in the winter.
I was initially told (on the phone) by National Grid that I can't dig the line for the electrical conduit. We'll see as I get closer and someone comes out to give me a firm price, etc.
What info can you point me to for your Steel Frame? I'm wondering if that's the way to go vs. timber frame since the style of house I'm looking at wouldn't benefit from the timber frames.
/ Off-Grid Solar Setups #32
Chris,
I dug my trench, installed the pull boxes and installed the conduit according to the power company's specs. These were minimum 5' deep to the top of the conduit, approved pull box every 100' and 3" PVC conduit with sch 80 risers. They also wanted a pull line installed in the conduit. Then they inspected it and installed the wire, etc.
My 48 X 60 steel frame came from Miracle Steel (now out of business) and was designed to be a steel shop building. I added overhangs and deleted the external steel siding so I could build it with conventional wood framing. The roof perlins are 2X10s sitting on 24" centers on steel trusses placed on 12' centers with a 4 & 12 pitch. Roof is double sheeted with OSB.
/ Off-Grid Solar Setups #33
<snip>.
There are third party contractors here in Maine that install electric service that is accepted by the utility. They usually are less expensive. The only difference I could find between the utility and contractor install is if the utility does it they will maintain the line to the transformer (last pole in my case). If the contractor does it, then tree trimming and repairs are on me. I chose the utility but I only have three poles, about 600' so the price difference wasn't that much.
You could check into that to see if it is an option for your location.
/ Off-Grid Solar Setups #34
DIY PV is very quick pay back (our electricity is ~ $0.13/kWh) - looking into adding it to current house but most likely will wait and install during the build of next house.
How large of a system do you have that triggered the "industrial generator" interpretation? around here I think it is 15 kW
Here it is 10 kW peak DC. We have 24 kW peak DC with room on racking for another 8-10 kW. It should generate little over 36,000 kWh/year. I figured when I add split unit heat/AC in the shop it will generate just about what we will use. There is a link to our PV under my signature.
Here is a link to passive heated building not to far from where I live: The Zen of Passive Solar Heating Panel Design
/ Off-Grid Solar Setups #36
Regarding isolating the slab from ground temp, I have used a system of interlocking plastic domes called cupolex . no serious foundations needed unless significant point loads. Instead, it acts like what we call here a floating or raft floor.
Cupolex Commercial Residential Gallery | Cupolex Building Systems
Generally touted as a way to conserve concrete but can decide what top thickness required if chasing thermal mass. Not complete isolation but good enough compromise given the price and time savings.
/ Off-Grid Solar Setups #37
This can also be done with "void forming", which accomplishes the same thing, but should be simpler and cheaper to do because it uses a cardboard type material that goes away and leaves open space.
Isolation from dry ground is something I don't worry about. Heating some dry ground below the slab with direct conduction, only increases the affective mass somewhat and seems the same as increasing the slab thickness. In my case I put in an 8" slab to deliberately increase the mass. Heating some ground under the slab does not necessarily mean heat loss.
Some radiant is designed to be as low mass as possible and some to be very high mass. Each has their value for specific applications. For instance, a low mass system could give you a quick shot of heat in the morning without a lot of BTU loss when nobody is home during the day and a high mass can act as partial storage to lower the average solar temperature and actually increase efficiency. It also stabilizes the temperature in the house. In my case, I like the stability, even though I like windows open as much as possible. When heat is needed, it often doesn't have as far to go, or as much to make up and severe winter temperatures in the garage can be weathered longer without freezing a pipe.
In multi-floor homes the slab basement can take the cold edge off the entire house. Then radiant zones in the bathrooms and kitchen greet people when they get up, by warming their feet. Since the baths and the kitchen are relatively small areas, the boiler appears to be oversized and heating response is fast. Timing the thermostat means the floor is warm when they get up, but does not stay warm all day, therefore the bill stays low and the overall temperature stays even. A warm greeting without overheating the house.
Many older radiant heated homes are VERY inefficient because of large single pane glass and no roof or wall insulation. In those cases, it's very important to time the system. The underslab, potential losses are not only impossible to deal with, but not a measurable portion of the overall problem.
/ Off-Grid Solar Setups #38
Another we looked at is that former being a series of bladders that double as water storage once concrete has cured.
/ Off-Grid Solar Setups #39
The Battery Show exhibition is on soon ( The Battery Show | Home ). I suspect two things:
1. What will be revealed at that show will amaze many people. I haven't been so stoked with the near-commercial battery tech coming down the pipeline as I am right now. People use the term too often but it's game-changing, me thinks.
2. The financial ponzi scheme that has propped up utterly unsustainable greed and immorality is likely to topple off a cliff, wiping out almost all substantial funding routes open to all but a few of the great tech advances. The race is well and truly on between bringing these advances to market, and there being a market left to tap into to fund such tech. Personally, if I had to choose between getting the tech and the next great economic crash, I'd choose the latter because the mo-fo world deserves an absolute ***-kicking over its behaviour for too many years now, as much as it will also hurt many people who don't deserve it.
/ Off-Grid Solar Setups #40
2013 FREIGHTLINER Cascadia (A61307)
2013 FREIGHTLINER...
2017 Nissan Quest Van (A61569)
2017 Nissan Quest...
2016 RAM 5500 Bucket Truck - Cummins Diesel - Auto Trans - 4X4 - Terex LT40 Boom (A61306)
2016 RAM 5500...
2018 FORD F-350 FLATBED (A60736)
2018 FORD F-350...
IMPORTANT PLEASE READ!!!! TERMS AND CONDITIONS (A61165)
IMPORTANT PLEASE...
New Quick Attach Hay Spear (A61166)
New Quick Attach...
