Kioti DK40se hst - log splitter?
/ Kioti DK40se hst - log splitter? #1
southerniltractor
Caryle, IL
Kioti DK40se HST with FEL, Simplicity Landlord, JD130
Greetings,
I've got a 2011 DK40se hst and I'm shopping for a 3 point log splitter. Based on my past wood splitting, I need a 27 ton or better splitter for the large oak and elm that often populates my woodpile. I went looking for a 3-point splitter and I'm not finding anything that can give me that kind of power with the 2600 psi my hydraulic system produces.
I'm about to give up on this tool and buy a stand alone splitter with a gas engine. Has anyone ran into this issue and how did you solve it?
Thanks,
Mike
/ Kioti DK40se hst - log splitter? #2
Greetings,
Thanks,
Mike
Considered the option, and ran into the same problem. I couldn't find a decent powered splitter that my hydro system would run. I decided I didn't want the tractor tied to the splitter anyway, and went with a stand alone that I pull behind the tractor, unhook where I need, and then the tractor is free. For me, the cost of a remote and splitter was the same as a stand alone.
Thanks - I'm doing the same thing. Found a good stand alone splitter and buying tomorrow.
/ Kioti DK40se hst - log splitter? #6
The choice for me came down to did I want my expensive tractor sitting there running and using more expensive diesel vs. a small displacement gas motor. Also, the smaller self contained unit could be moved around my wood pile easier than my tractor, less distance moving the logs to the splitter. Went to Tractor Supply Co and got a $1,000 unit with a 5 year warranty, and they would pick it up and deliver it if it broke. To me that was a guarantee of at least 5 years of splitting for $1K.
I ended up going with an Ariens 27-ton splitter. The splitter is built in America and comes powered by a Subaru gas engine. I did look at some less expensive splitters at Rural King, and those were cheaper, but built in China.
I had my kids helping me split the other day and the Ariens made quick work of 12-18 inch diameter cherry and grunted just a bit while splitting the 2-foot diameter oak. The best part was watching my son operate this machine while I enjoyed a cool beverage! These kids are finally starting to pay off!
2008 FORD F150 REGULAR CAB PICKUP TRUCK (A66091)
2008 FORD F150...
2012 FORD F150 REGULAR CAB PICKUP TRUCK (A66091)
2012 FORD F150...
STERTIL SKY LIFT (A67714)
STERTIL SKY LIFT...
2015 Audi A4 AWD Sedan (A61574)
2015 Audi A4 AWD...
2009 FORD E350 CARGO VAN (A66091)
2009 FORD E350...
KOMATSU D155AX-3 Final Drive (A68134)
KOMATSU D155AX-3...
