Ford 1700 lift problem (yes again)
/ Ford 1700 lift problem (yes again) #1
Bender57
liberty hill, texas
ford 1700
Having some problems, 3 point that will raise and lower but when it is stopped I hear the relief valve. no matter where its stopped.
After a short while 5 min. or less it is real bad and just wont move at all but them out of the blue where it raises and them lowers.
when this is happening the front bucket acts the same as the rear lift. This problem has been with the tractor for some time now but it has gotten worse and to the point cant be operated.
I do have pressure suing gauge until it hits the unloader
The relief valve is clean but no shims
Rebuilt the pump and fluid and filter is clean
I am thinking of going into the spool valve next. Any thoughts
/ Ford 1700 lift problem (yes again) #4
According to the service manual your relief pressure should be 2062-2200 psi. It says the 1700 is adjusted via lock nut and adjusting screw (no shims) adjusted at the lift position control valve. I would think the loader relief should be adjusted slightly lower to keep from straining the pump.
But that still does not explain why the overload sounds off when the 3 point is raised and why I loose total hyd a short time after that. Hyd. will come back for 10 seconds then be gone again for longer time say 1 min.
RPM has no effect on the problem
/ Ford 1700 lift problem (yes again) #6
Take a look at your spool valves. The manual I have was pretty lame on them. So I took notes and made drawings as well as marked where the adjustments were before I messed with them. Look first for bad O-rings busted or rusted springs and seats i.e. general dirt. Does your model have draft control?
Yes it has the draft control. I am thinking its in the spool valve. I have had this problem for some time now 2+ yrs and only getting worse.only use the tractor maybe twice a yrs
/ Ford 1700 lift problem (yes again) #8
If it is used that infrequently then it could be as simple as cleaning the ports and seats. When I had problems I checked the spools first, trying minor internal adjustments and reinstalling to see if it made any difference. Mine was ultimately a bad lift piston seal and I found it is the easiest thing to check without expensive jigs and test pumps.
/ Ford 1700 lift problem (yes again) #9
could you tell me where the filter on hydraulic pump is? I have not opened the cover yet just wondering what all I'm getting into.thanks
/ Ford 1700 lift problem (yes again) #10
In the bottom of the axle center housing is what the manual says. The picture shows it is accessible without taking the center housing apart.
So here is the latest update.
Took apart the spool valve and checked for dirt. none found and oring looked good
Jacked up the back of the tractor to make sure its getting oil and that the pump is primed
Removed the little arm from the lift lever as book instructed as tried full up with gauge attached. never saw over 650-700 psi.
the pressure was never constant and would go back to 0. hyd. still noisy and sounds like it straining. the only thing I have not done is remove the lift cylinder and inspect it.
Will be doing that soon, if nothing is found there it will be a pump replacement next.
Any thought from experts would be nice
Thanks
/ Ford 1700 lift problem (yes again) #12
So here is the latest update. Took apart the spool valve and checked for dirt. none found and oring looked good Jacked up the back of the tractor to make sure its getting oil and that the pump is primed Removed the little arm from the lift lever as book instructed as tried full up with gauge attached. never saw over 650-700 psi. the pressure was never constant and would go back to 0. hyd. still noisy and sounds like it straining. the only thing I have not done is remove the lift cylinder and inspect it. Will be doing that soon, if nothing is found there it will be a pump replacement next. Any thought from experts would be nice Thanks
Have you cleaned the screen for the hydrolics yet. There is no filter, just a metal screen. Sounds like it is clogged to me.
/ Ford 1700 lift problem (yes again) #14
650-700 is not near enough pressure. Pump may be going or did you service the filter? I know it's a screen, but Shibaura and the service manual call it a filter.
/ Ford 1700 lift problem (yes again) #15
Yes a long time ago in the trouble shooting process
When I had my 1700 I had to clean the screen on a yearly basis. I take it you changed the fluid when you cleaned the screen. Sounds like pump problems or there is a clog somewhere.
