Snow blower
/ Snow blower #1
RCraig
Lebanon, PA
154 Cub Lo Boy
I am widening a single stage snow blower to fit my tractor. I have the shell done and the auger is fit up. I am having trouble finding information on how fast I should spin my auger. With the creeper gears on my machine I can travel real slow but what RPM do I need to "throw" the snow out of the chute? Of course this is a do it yourself project and the blower is a retrofit from something else.
/ Snow blower #2
A mile a minute isn't too fast to blow snow. (might be fast for your auger though)
Do the math on the auger diameter (Pi X D) and see what drive combination might come of it. Somewhere around 1000-1500 rpm is my bet.
/ Snow blower #3
What was the the fan to auger ratio of the original blower? I wonder what the ratio is of a comparable unit like you re making? Would the below work?
Let's say you had a 38 inch blower and for 1 revolution of the auger you get 3 out of the fan. Then you increase the width to 48 inches. That's a 26% increase in width. Increasing the auger speed by 26% would give you 3.78 rev of the fan for 1 of the auger. on the wider unit.
/ Snow blower #4
If the OP really has a single stage as stated, there wouldn't be a fan, would there? Isn't a single stage just a quick auger?
/ Snow blower
It is a single stage. No fan. I am leaning towards starting at about 800 rpms and the working up if I need to. My concerns are, if it is too slow it will not clear snow, too fast and things start to come apart. I started with a 32" MTD lawn mower mount that was given to me and now I widened it to 60". I work as a welder/millwright so the mechanics are not too hard. Information is the tough part
2019 Ford F-150XL (A64119)
2019 Ford F-150XL...
1963 Ford Falcon (A62613)
1963 Ford Falcon...
Landhonor MPF-11-2000G Skid Steer Pallet Forks  (A62679)
Landhonor...
PALLET OF AMMO BOXES (A64281)
PALLET OF AMMO...
2023 Top Air ATV 200 Gallon Pull Type Sprayer with 30ft Booms (A63688)
2023 Top Air ATV...
Mahindra Emax 22S Loader Tractor (A66285)
Mahindra Emax 22S...
