Kubota B2920 Power Beyond Port
   / Kubota B2920 Power Beyond Port #31
Sorry, but you are looking at the wrong port.
The correct port for the return is in fig 12 in the woods BH-65 pdf
3pt input is in fig 11
I know where both ports are.
If I could send you the manual , I would.
   / Kubota B2920 Power Beyond Port #32
Here's some pictures taken from Woods BH6000 install for Kubota tractor series B2x20.
   / Kubota B2920 Power Beyond Port #34
Thanks for posting those attachments.
How do you grab pictures from a pdf?
   / Kubota B2920 Power Beyond Port #35
I had to print out the pages I wanted and took.photos of them. The pdf was too big and I don't have software to edit pdfs.
   / Kubota B2920 Power Beyond Port #36
Figure 11 item 5 is the PB port on the loader valve, figure 12 item 3 is the pressure IN for the 3ph.
JJ, now that we have some pictures hopefully we are on the same page.
   / Kubota B2920 Power Beyond Port #37
Ok now I'm confused. When I use my subframe mounted backhoe, I don't use the 3 pt lift and would have no need to use the TNT.
Could I put the TNT valves upstream of where the backhoe would be connected and have the pb for the last valve continue to the 3pt?
Then when I connect the backhoe, I would connect the input to the hoe to the pb of the last TNT valve and the output from the hoe to the hose or line going to the 3pt?
That is right -- what I was advising against in an earlier post would be using the existing backhoe lines to feed a bank of rear remote valves, since you'd still need to add return lines to the tank somehow. So may as well put the remote valves upstream of the backhoe line, with their own return, and PB out of the last valve feeds the backhoe.
I always think of "inserting" items in the PB loop, which means you continue the rest of the loop as it was. Just need to be aware that many items will need their own tank return lines.
In reality, the backhoe was inserted in the PB loop, but without a separate return. Only makes sense if the 3-pt valve is not used and locked out.
   / Kubota B2920 Power Beyond Port #38
Good way to do it is take a screenshot when the PDF is on your screen. You can normally take a capture of just part of the screen too.
   / Kubota B2920 Power Beyond Port #39
I'm trying to hook up a third function valve to a Kubota B2920, and I'm trying to determine where the power beyond port is
This is a picture I got off the net, not mine but same valve
Here is a valve diagram and where the hoses appear to go
Watkins,
Getting back to your original post: I am not sure what you are trying to do, only assumption I see is a 3rd function to operate a grapple, is that right? If not, then what is the the purpose?
The picture appears to depict the distribution block on the rear of the HST and the diagram appears to be the FEL joy stick valve; right?
Is the intent to install a manual valve in the circuit at the FEL control or at the rear of the tractor at the distribution block? Or do you have BH connections and want to connect there.
How to you want to control the 3rd function: Solenoid valve in the lines to a set of FEL cylinders (normally the curl), manual spool Valve, manual double selector valve?
Answer these questions and maybe we can collectively get you a good answer for your perusal.
Ron
   / Kubota B2920 Power Beyond Port #40
JJ, if you have a full function PDF program it is easy and I could walk you through it on a phone call. In Acrobat reader you cannot do it. As GP said he had to go the long way around.
PS, it was a great day when TBN added PDF to OUR upload capability. I just print every thing to PDF and it is easy to transfer and to store.
Ron
2021 Dosko 337S-13HC Walk-Behind Stump Grinder (A49461)
2021 Dosko...
2014 International Durastar 4300 (A50323)
2014 International...
2007 Mitsubishi Fuso FE84D 16ft Dovetail Flatbed Truck (A50323)
2007 Mitsubishi...
PALLET OF TARPS, UMBRELLAS, AND PORTABLE SHADES (A50854)
PALLET OF TARPS...
John Deere 455G Loader (A48837)
John Deere 455G...
3in Poly Pipe (A49461)
