BX Steering issue
/ BX Steering issue #11
There is a groove on each end with an internal circlip. You only need to remove one end to replace the oring thats bad. ... Look for a small hole on the outside surface opposite the groove. Pushing a probe into this hole will help you displace the circlip so you can remove it.
larry
/ BX Steering issue #12
I'm having the same issue on my BX2660. It's 6 years old with 240 hrs and gradually getting worse. Just went to dealer and ordered new cylinder. They said rebuild was only $10-15 cheaper. $300 for new cylinder plus labor. I will be installing myself.
/ BX Steering issue #13
The fix is simple. Replace my o ring in my shop in a short time. Be sure and mark your ball joint settings or realign after the repair.
Lot cheaper than the shop if you have a little time.
/ BX Steering issue #14
Youve been taken advantage of.
/ BX Steering issue #15
Yeah! ... A dollar for the oring and an hour of your time. On the BX1500 the ball joints just unscrew from the hyd rod ends, so re alignment is not an issue.
/ BX Steering issue #16
How do you get the clip out? There isn't any hole on the outside. I have a picture but I can't get it to upload.
/ BX Steering issue #17
,,,:confused: ... 2 possibilities; 1] There is a hole and its gooked up so you cant see it, or 2] Its been changed by Kub in some way.
The 1st time I changed mine I didnt notice the hole, but was able the get the clip out with 2 small screwdrivers. The wire clip/ring has a reverse bevel on each end. This presents a point that you can hook a screwdriver blade under and pry the tip of the ring up a little. But before you try you have to relieve the outward pressure against the ring by the parts it has retained all this time against the hyd pressure while in use. Find a tube that will fit close inside the ring and just give a smart tap with a 2# hammer. The rod guide and seal should move in enuf for you to see. Now remove the clip. Pry up the tip slightly and get the 2nd fine bladed screwdriver under the end of the ring and carefully pry it out. Be careful it doesnt have any opportunity to fly.
Tap the rod thru with a soft hammer from the other end til the central piston hits the inside of the unclipped end and drive it out. The oring is on the central piston. Reassemble in same orientation so mated worn parts are still adjacent. Itll be easier next time. ;)
larry
/ BX Steering issue #18
I talked to a kubota tech yesterday and he said the rebuilds usually don't hold up very long. Said it's best to replace the cylinder. I verified there is no hole on the outside. Since I ordered a new cylinder I will see if I can get this one apart based on your instructions. Thanks for the help.
Update: I got the clip off and drove the end seal loose. The seal will move about 1/4" since removing the retainer but won't come out. The opposite end is even with the cylinder. Does it need to be driven out further? I tried but didn't want to go overboard.
/ BX Steering issue #19
Don't understand why they wouldn't hold up unless the ram is all scared up. Sounds like a ploy just to sell a new one. All of the cylinders that I have had redone never failed an was told they are better then new cause of better quality parts an seals used.
/ BX Steering issue #20
Yes. This dealer story speaks poorly of the attention paid and/or skill of their mechanic. It amounts to an excuse in advance for failure. I suspect that most premature follow on failures are due to scarring the ends or body of the rod, or to replacing all the seals provided in the "seal kit" even tho the end/rod seals are fine. These are more difficult to replace and damage could be done by inexperience with such things. -- The oring piston seal is what wears out way early. It is very easy to replace. Merely assuring that it is well lubed and can encounter no burrs or sharp edges as it re enters the cyl bore assures that its service life will be customary.
From the very 1st/ original ring the steering issue has begun showing after about 600 hrs of use, and nursed to ~ 700 before changing the oring. At 2100 I have changed several; the last at 2000. For the last change I used an oring from McMaster Carr, rather than from a cheap assortment. Maybe better? Well see. :confused:
The original end seals are fine.
larry
Tandem Axle Rear Trailer Frame (A55851)
Tandem Axle Rear...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2014 Chevy Malibu Sedan (A59231)
2014 Chevy Malibu...
2001 CHEVROLET C8500 FLATBED TRUCK (A62130)
2001 CHEVROLET...
2011 Mercedes-Benz E-Class Sedan (A59231)
2011 Mercedes-Benz...
