Tire Selection which tire size for hilly terrain?
/ which tire size for hilly terrain? #1
MoreDirt
Prescott, AZ
shopping
Greetings all - i am looking at a few 4x4 tractors in the 30 hp range to purchase. I have many hours operating Case and JD commercial tractors on our 6 acres and even some hours on an old Ford farm tractor.
I looked at a friends Lenar 274-1 that he wants to sell. He said the tall narrow tires are not stable on hills. We have a mix of hills and flat terrain. Is this a better choice for hills?=http://aztractorsales.com/usedkubota2650tractorforsale.php
What can you tell me about tire size in regard to stability on hills? Can you put fatter tires on these?
Thanks in advance for your thoughts!
/ which tire size for hilly terrain? #2
Sure, you can put fatter tires on your tractor. No problem.
My 1964 MF135 diesel has 18.4-16 rears loaded 2/3 full of water. Rims are 16 inch.
The front axle spindles are shorter than normal to keep the tractor level.
Tires like this are available at most stores that handle ag tires. Typical use for this size tire is on farm equipment like combines and farm fertilizer spreader trucks that need high flotation tires to work in soft soil.
Good luck and be careful on the slopes.
2004 Rogers Detach Lowboy, 28' Well, Tandem Axel (A62679)
2004 Rogers Detach...
2014 INTERNATIONAL LF687 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2014 INTERNATIONAL...
John Deere 4955 (A64119)
John Deere 4955...
2006 Mack Granite CV713 Dumping Flatbed (A62679)
2006 Mack Granite...
6 Band Wooden Barrel (A61574)
6 Band Wooden...
TEST YOUR BID BUTTON! (A63291)
TEST YOUR BID...
