Scv multiplier for fel third function
/ Scv multiplier for fel third function #2
Do a search here on the forum for the term "diverter", it's discussed weekly...
There are several forum sponsors that sell simpler setups, for quite less especially if you want to turn some wrenches yourself.
Here is the one we offer: Ken's Bolt on Grab Hooks <<Hydraulics>>
The one you linked is most often used on rear remotes, but due to the weight hanging on the couplers it might not be the best setup unless its somehow supported.
/ Scv multiplier for fel third function #3
A couple of potential problems with those. Even though the male ends are adjustable from 2"-2 1/2" on an eccentric type fitting, they DO NOT fit ALL stock rear remote spacing. Been there done that. So it is possible that you purchase it and can't even plug it in. Double check your spacing before you make your purchase. I'm thinking that it will not work with your Massey.
Second thing, do you really want that big hunk of metal hanging off of your rear remote outlets??? I would think that that alone would be un desirable, it was to me.
Not that hard to do a std type electric diverter and have a much cleaner install.
One other thing, if you are considering a diverter and it is your plan to use it as a 3rd function, why not use the loader valve as the feeding valve and have the control switch on the loader joystick where everything can be actuated with your hand staying in one place?
Just wondering. :confused3:
with out having any experience with them I was wondering if I ran two wiring harnesses, one the the scv and one to the fel stick, could the diverter be swapped back and fourth to add a 3rd function to the loader and a second scv remote as needed?
/ Scv multiplier for fel third function #6
A so called 3rd function can be inserted anywhere after the loader valve and controls hyd components like cyl and motors, etc..
A diverter can be used to switch hyd circuits. Another valve controls the flow, like loader, remote, etc.
/ Scv multiplier for fel third function #7
I looked into using a diverter when adding a grapple to my bucket, and was told they would sometimes stick or not reset under pressure. I went with a 3rd function valve instead.
/ Scv multiplier for fel third function #8
I was told my health care would be cheaper once...
Any valve can malfunction, even your 3rd function solenoid.
/ Scv multiplier for fel third function #9
Come to think of it, the guy who told me that sold me the 3rd function kit, for a few dollars more.
Kenny, my tractor is ratted at 11 gpm, is your valve 10 gpm max?. Am I really getting 11 gpm that far from the pump?
/ Scv multiplier for fel third function #11
Yes, ours is rated for 10gpm. Generally when they are used on the FEL (like for a grapple) they never see max flow so it's a non-issue. If used on a rear remote to drive something with constant flow it might be a problem, but something like a TnT setup wouldn't matter either.
2003 International 4300 Flatbed Dump 571559 (A62613)
2003 International...
(INOP) 2018 FORD EXPLORER (A59823)
(INOP) 2018 FORD...
Stryker 1.5 yard Slide in Spreader Box  (A62679)
Stryker 1.5 yard...
New/Unused 3 Point Receiver Hitch (A65583)
New/Unused 3 Point...
Rhino SE415A (A64126)
2026 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2026 SDLANCH...
