Ford 800 boiling gas in tank
   / Ford 800 boiling gas in tank #1
gerytb
Cobden, IL
mahindra 4035, Kubota RTV 1140
Anybody ever heard of a Ford 800 tractor boiling gas in the tank? The tractor starts to surge under a bush hog load and worse when hot. If it is not dropped back to idle it dies. You can see and hear gas boiling in the tank.
   / Ford 800 boiling gas in tank #2
1, is your timing set correctly?
2, are your heat shields in place?
Thanks for the reply. Don't know about the heat shields. It was purchased used, so I have no knowledge of what might supposed to be there. I am also not sure that the exhaust is routed as originally installed. I cannot tell if it has been re-routed or not. I assume the timing is set correctly. It only acts up when under a load of bush hogging. Otherwise, pushing snow, grading etc. it is fine.
   / Ford 800 boiling gas in tank #4
In addition to timing, running a hair lean can make it get hot too.
As for you not knowing what it does or doesn't have, post a pic of the left side of the engine.
Or setup is the muffler elbowing off the back of the exhaust Manny, then laying parallel and above the Manny, with exhaust pipe coming out at the front of the tractor, going down. Then angling back under tractor.
The gas tank supports atop the head hop the vertical and horizontal heat shields that deflect muffler he's from the tank, which is very, very close.
   / Ford 800 boiling gas in tank #5
If the unit is getting hot enough to boil the gas in the gas tank, it is also boiling the oil in the engine. It sounds like you have a serious cooling problem. What temperature is being show on the temperature gauge? Does it have a gauge or a idiot light? has someone disconnected the heat sensor? is the fan spinning when the engine is running? With the engine off see if the fan will spin freely when turn or is the fan belt tight enough to hold it? Does the unit have the original water pump and the impellers on the pump have eroded off over the years.
My suggestion would be to solve the heat problem before continuing with using the unit or you are shorty, if not already going to have a serious problem.
   / Ford 800 boiling gas in tank #6
Here's my 950, same basic setup but mine is a rowcrop trike
Notice above the manifold is the muffler, above muffler is a metal panel, and above that is the lower edge of the tank. Not pictured to the rear is a vertical he's shield on the rear fuel tank bracket.
http://photos.yesterdaystractors.com/gallery/uptest/a24272.jpg
   / Ford 800 boiling gas in tank #7
E10 will boil way sooner than non-ethanol fuel.
Thanks for all the helpful replies. I am actually asking this question on behalf of a friend. I will forward the pics to him and the pic sent by Soundguy will help immensely.
   / Ford 800 boiling gas in tank #9
agreed... i'm not fond of ethanol blends in these old machines... carbs seem to hate it...
   / Ford 800 boiling gas in tank #10
I've seen various brands do this with today's blended gas. Ethanol in the gas is the culprit. I'd start by servicing the cooling system, flush the radiator, new coolant, change the thermostat, etc. Engines running at a higher RPM will tend to get warmer than the same engine at a lower RPM.
2017 John Deere 5090GN (A53317)
2017 John Deere...
2022 Bobcat T66 (A53317)
2022 Bobcat T66...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A56438)
PENDING SELLER...
2020 dodge Charger Sedan (A59231)
2020 dodge Charger...
Craftsman 42 Inch Riding Mower (A57454)
Craftsman 42 Inch...
20FT X 30FT STEEL CARPORT (A58214)
20FT X 30FT STEEL...
