SandburRanch
- Joined
- Oct 12, 2010
- Messages
- 1,543
- Tractor
- NHtd75
Use concrete wire cages. Cut in half to stack for storage and cut with fence pliers.
I took a 50" tall by 16' long livestock panel and split it both directions with bolt cutters. Then i bent each piece in half. I now have an "A" frame that I put between four tomato plants planted in a 2' x 2' pattern. I then use twine to help get them started to climb up the support.
I did this after I got tired of all the work of tying them to a wood stake or setting up cages that either break or blow over. Now I have rigid support that are easy to set and then remove in the fall and they never fall down. They are made out of 1/4" rod and the sharp ends stick in the ground. The A frame shape and 2'x2' base make them very sturdy. I have been using them for about ten years now.
A new livestock panel is $15 locally and I can cut it in about 5 minutes.
Mine being A shaped stack very well for storage
Wazoo Some of you guys look to have enough plants to feed the world. I use "standard" cages and have four plants. I don't can tomatoes. Just enough to have fresh tomatoes during the season.
Lakngulf - your photos remind me of our first garden here, some 33 years ago. We had 30 hills of zucchini - we froze 65 quarts of shredded zucchini and people became upset when we slipped sack loads of them in their cars, at work. The neighbors cattle would eat a lot of them too. We sure learned something after that garden the first year.
Lakngulf - your photos remind me of our first garden here, some 33 years ago.- we froze 65 quarts of shredded zucchini and people became upset when we slipped sack loads of them in their cars, at work. The neighbors cattle would eat a lot of them too. We sure learned something after that garden the first year.We had 30 hills of zucchini
We grow our tomatoes in raised beds. I run cattle panels along the sides of the bed and plant the tomatoes next to the panels. Then strap the panels as the tomatoes grow.
We use cattle panels as well. One 6' T post at each end, one in the middle. Approximately 5 plants per panel. We also use them for peas and pole beans.
Use 8" long galvanized concrete rebar wire ties to attach the panels to the post (with the little 'spinner' tool for them, they come with a loop in each end). A near lifetime supply is a $50 roll of them. (I forget how many thousand) They are cheap, cut off and discard at the end of the season. Pull the T posts, and hang the panels on big nails in the garden fence posts.
As others have said, I made my tomato cages of concrete reinforcing wire about 2' diameter. I cut them so the bottom wires stuck into the ground, but I also used two 1" x 2" wooden stakes for each cage because I had more 1" x 2" lumber than I knew what to do with.:laughing: I was planting a dozen each of 4 varieties of tomato. At the end of the season, I used a machete to chop off most of what had grown out through the cages, which made them easy to pull up and store in the barn for the Winter.
I use the same machete to chop up the dead vines before they go into the compost.
