5093E 4wd shifter problem
/ 5093E 4wd shifter problem #1
1Lawman
Joaquin, TX
2012 John Deere 5093E
My 2012 5093E is very difficult to shift OUT of 4 WD..Any ideas?
/ 5093E 4wd shifter problem #2
Best way to shift out of 4wd is to put light pressure on the lever while slightly turning front wheels either left or right and back to straight while moving slowly.
Another way is to stop and reverse direction of travel while putting light pressure on the 4wd lever. All tractors I've owned (green, orange, red) along with jeeps and trucks have worked this way. Give it a try.
/ 5093E 4wd shifter problem #3
if you have a loader lift front end a little it will come out easy, if it has just started doing it might check air pressure in the tires one could be low causing it to bind a little
/ 5093E 4wd shifter problem #4
When mine winds a little tight, I just keep some light pressure on the 4wd lever and back off the forward pedal quickly, comes right out. Or be ready when changing directions is a good time to shift out.
Whis... Good point on the air pressure in the tires. Will follow up on that.
/ 5093E 4wd shifter problem #5
I just lean on it while rolling straight a foot or so and she pops out easy.
I was thinking about automating it with a solenoid or something, but you'd need a spring/shock in the mechanism to account for not ripping the arm off when it's sticky.
Thanks guys..You've given me several things to try...
Piece of cake! It's all technique..I was stopping to shift in and out..Works MUCH better to lean on the shifter, speed up and then slow down from slow ground speed..Slips right in and out! Thanks..
/ 5093E 4wd shifter problem #8
Late to see this. I also have the same problem with my 2010 5093E. I shift out of 4WD by switching to a low gear, start rolling forward, and pull back on the lever.
I suspect it's common for this tractor..Have you had any other problems? I ask because my hydraulics run hotter on this tractor than my Kubota did and I can hear a rattle from the rear..
/ 5093E 4wd shifter problem #10
Dumb Question #329A.1(b): How do you know if the hydraulics are hot?
My main problem yesterday was that the AC worked, but was overheating the engine while bushhogging a way-too-late first cutting. So at about the hottest point of the day, I switched off the AC, the temp gauge dropped nicely, the tractor ran well for the rest of the day, but the cab became a hotbox. It was about 93 yesterday and dripping humidity in Virginia. We have had the AC compressor replaced two years ago and the engine oil is overdue for replacement. That may be related. The tractor is not in constant use.
I grab the hydraulic lines at the back of the tractor close to the hydraulic connections..Those lines are metal and get so hot I cannot hold them with a bare hand..
My tractor has been to the dealer twice for a.c. problems.
/ 5093E 4wd shifter problem #12
I'll check that out on my metal lines. There are signs of a small leak under those lines (right side) on my right rear axle. I don't see any leaking, but the residual grime is definitely there.
I traced my AC latest overheating problem back to an operator problem. The radiator wasn't hosed off after the last mowing/baling job, which was done late. So the radiator screen was clogged with hay seed. That was hosed out this morning and my brother says that the temp gauge is behaving well. I have a love/hate relationship with my JD, but I think the feeling is mutual.
I had Kubota and loved it for many many years..I regretted trading for my 5093E but it must be growing on me as I had a chance to sell it for what I paid and didn't do it so I know what you mean...
/ 5093E 4wd shifter problem #14
... I shift out of 4WD by switching to a low gear ...
4wd come out much easier in
Low range A OR mid range B
As mentioned with light pressure on shifter, clutch work and / or pulling slightly forward or backward.
All technique as you said :-D
/ 5093E 4wd shifter problem #15
The devil you know...
/ 5093E 4wd shifter problem #16
Green Tractor or go home LOL
/ 5093E 4wd shifter problem #17
Mine is a little difficult too. Haven't come to peace with a method, but I have a few more things to try now...
/ 5093E 4wd shifter problem #18
I checked the metal hydraulic lines after doing some bush-hogging the other day and sure enough they were quite warm, although not so hot that I couldn't hold them. So what is the impact of hot hydraulics? I should change hydraulic oil more often?
/ 5093E 4wd shifter problem #20
My 4wd is hard to do as well. When I take it in and out of 4wd, I get it rolling in about B range 4th and flip the shifter into neutral and pop in out when there is no load on it. Works good for me. Mine had A/C issues as well. Had it in 3 times last summer for it. I carry a can of Freon in there all the time. now. last year, I had to charge it up before I used it every time. I think they might have finally found the leak, because this summer, it seems to be working . I also use the a/c on defrost in the winter to pull the moisture off the windows. I works much better than just heat.
2014 Nissan Versa Note Hatchback (A66738)
2014 Nissan Versa...
2000 Toyota 4Runner SUV (A66738)
2000 Toyota...
2014 KOMATSU D65PX-17 CRAWLER DOZER (A65056)
2014 KOMATSU...
2019 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A69167)
2019 FREIGHTLINER...
2016 Land Rover Discovery Sport SUV (A61574)
2016 Land Rover...
2017 MAC Half Round T/A End Dump Trailer (A68183)
2017 MAC Half...
