New trailer discussion & ideas
/ New trailer discussion & ideas #21
/ New trailer discussion & ideas #22
I recently finished my trailer research and what I settled on was a 20', 14k#, low-profile, tilt-deck from Load-Trail. The TL14:
*NEW* Low-Profile Tandem Axle Tilt Deck 14,000 Lb 6" Channel Frame Load Trail Trailer Manufacturing
I chose it because the tilt deck design means easy loading and unloading and no messing around with ramps. The 4' stationary section gives you a place to strap down an implement or a pallet and still be able to tilt the deck. It's more pleasant to load and tow since it's so close to the ground.
I considered power tilts and a lot of other stuff. In the end, this was my favorite option. If your M6800 fits between the wheel wells, I think it would be a good option for you.
/ New trailer discussion & ideas #23
I have a PJ 14K full deck tilt trailer. They also make full tilt deck over trailers that would work for you.
PJ Trailers - Deckover Tilt (T8)
First off thanks to everyone for helping, I must not be as good at searching as I thought I was.
George that is the trailer I had settled on except it was a deckover and if the dealer had one when I got there I would have gotten it. but now with all these options I have, I will have to wait and see.
/ New trailer discussion & ideas #24
Did you ever say what you were towing with? I wouldn't have a deckover behind anything smaller than a modern 1-ton truck. They're heavier and putting the load up higher makes them less stable going down the roads. Even then, if I can get away with it I'd rather have the deck between the wheels.
/ New trailer discussion & ideas #25
2008 GMC 3/4 Ton
/ New trailer discussion & ideas #26
If it is a gooseneck the 3/4 ton will handle it just fine.
Here is my 2006 GMC 3/4 ton with the heaviest load that I ever puled. Hauled from Rogers, AR, to west of Oklahoma City in September of 2009.
12,640 on the deck, 3440 on the ball, 14,200 on the axles. Was very stable.
attachment.php
attachment.php
/ New trailer discussion & ideas #27
I agree. No need for a 1 ton for the right size trailer. I pulled a 7 ton 25' deck over gooseneck daily with an '04 GMC 2500HD. Truck was rated for 15,400. Never had any issues even once when I overloaded it with a 15,000# ish scissor lift that I hauled 80 miles. Plenty of options of deck over that are well suited to 3/4T SRW trucks
/ New trailer discussion & ideas #28
I am not saying it will be legal or by the books but 3/4 tons will pull large loads fine. I have scaled 27k gross with my 3/4 ton and gooseneck dump trailer when they loaded too much at the gravel quarry. I hauled it 30+ miles and it towed and stopped fine. I wouldn't make a habit of it but they are capable trucks.
/ New trailer discussion & ideas #29
Thanks, I have considered a goose neck but my truck is not set up for one and I am considering a new truck in the next three years so I don't know if I want to upgrade this one. it is a 2008 with only 98K miles on it. I have pulled 14K on it with no problem.
/ New trailer discussion & ideas #30
I have noticed the deck-overs look heavy too. They are pretty much two trailers, a frame underneath to hold the suspension and the tongue, and another frame above for the decking.
/ New trailer discussion & ideas #31
I have personally seen one of these used. It was pretty neat.
Rollback Trailers, Tilt Trailers & Heavy Car Haulers in Texas | Kwik Load Trailers
It has a hand brake that you lock down to hold the trailer wheels in place, pull some pins out in various places, and then back the tow vehicle up.
I built a tilt bed deck-over for my brother in 2007. Now, for myself, i am building a fixed deck-over on 195/50R13 wheels. Small enough to get a two foot deck height, stabile enough to track well, and enough air in them to smoothen out the bumps when driving with an empty trailer. I will use knot free Douglas fir ramps which are about as strong and as light as aluminium, and support the back of the trailer with foldable stands.
For me, only fixed axles and towbar, i dont want any slack as it allways jerks when driving empty.
/ New trailer discussion & ideas #32
:confused:
Every flat bed trailer I have seen has 2 main frame rails running fore/aft and cross rails on them to support the wood decking. Doesn't matter if its deck over or deck between. They may look heavier just cause they are. Deck overs are usually 12k or higher where many of the deck between are 7 or 10k
/ New trailer discussion & ideas #33
:confused:
This is what I was talking about. One frame on the lower level, another that is tilted. Most heavier rated deck-overs have this even if they don't tilt.
/ New trailer discussion & ideas #34
Well of course a tilt deck needs 2 frames, that's not the same thing at all.
I beg to differ. I have never seen a commercially available fixed deck-over with any design other than 2 main frame rails (usually C channel) then cross rails then the decking. And that is everything from 3.5t right up to transport trailers.
/ New trailer discussion & ideas #35
Here's one.
A lot of the equipment trailers around here are built like the one above though, smaller main rails with a thicker deck frame on top of them.
The one we had was a weird one, it had single wheels made with very short axles. The axles didn't go all the way across the trailer, and the single wheels were in pairs on short axles, with one of the wheels way under the trailer. In other words you almost had wheels all the way across the center of the trailer.
/ New trailer discussion & ideas #36
That would track poor on highways where tractor trailer combinations have made ruts in the tarmac. My trailer is wide enough to run in the truck track, it reduces sway tendency very much.
/ New trailer discussion & ideas #37
I have been searching on the internet but can't find it. Maybe you guys know who made it;
At work they hired a guy to move these metal ship containers we use for storage. He comes in with a full size tractor trailer tractor, and a single axle flatbed trailer(5th wheel of course to hook to the tractor).
It was amazing to see what this thing could do. The 5th wheel pin on the trailer was not mounted to the trailer fixed. The pin was mounted to a hydraulic mechanism which let him raise and lower the whole front of the trailer in relation to the tractor.
Along with this, the single axle dually wheel set was not mounted stationary to the trailer either. It was mounted on some sort of track system and a very long cylinder. He could move the axle forward and back several feet. I am not sure what all else it would do, but he was controlling the whole thing by remote control, walking around the whole thing while he was working it.
/ New trailer discussion & ideas #38
I am still trying to find that trailer in the above post. While I was looking I ran across a picture of the bottom of the weird trailer we have.
(7) MISC WHEELED TRASH CANS (A64280)
(7) MISC WHEELED...
2014 Subaru Legacy AWD (A62613)
2014 Subaru Legacy...
KUBOTA RTV900 ULTILITY CART (A64276)
KUBOTA RTV900...
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A60460)
2018 Freightliner...
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A60460)
2019 Freightliner...
2008 Ford F-250 4x4 Crew Cab Pickup Truck (A61573)
2008 Ford F-250...
