M65 zero turn drive problems
/ M65 zero turn drive problems #1
MESSMAKER
Bluegrass,KY
DK4710SE
Been a good mower but one side is pulling weakly on the left side. It has a bit of chattering as well when you are going up hill. It has separate pumps and wheel motors. What is the most likely problem?
Dropped a # in my header it is a JD model m665
sorry
/ M65 zero turn drive problems #2
I'd look at the oil change frequency and filter change. If up to date, then I'd get a pressure check on the lines to track down loss of pressure. May help pinpoint the problem.
/ M65 zero turn drive problems #3
Check if the tire is not slipping on the rim due to low pressure or slime in it (if you used some).
/ M65 zero turn drive problems #5
Would that cause chattering?
That is what happened to our mower. I don't know exactly what you mean by chattering. Is it sound or jerky motion like something is slipping? Our mover developed slipping of tire on the rim causing sometime very jerky operation or complete loss of power. It took for a while to figure it out only after we bought and installed new transaxle. The transaxle is for sale now for about half price of new one.
Push the mower against immovable object such as tree and let somebody observe the wheel while trying to go forward. The tire should slip on ground not on rim. There is not much what can go wrong with pumps and motors on commercial mowers. The mechanic told me they should last several thousand hours.
Got the word today. Hydro pumps are bad. One is shot and one is below spec. Ouch
/ M65 zero turn drive problems #8
I have one for sale for about half price of new if it would fit on your mower. It has about 1000 hours.
Edit: Just re-read your post. It will not fit.
Sorry to hear that. Just curious. How many hours on the pumps?
Steve
Just short of 1000, so it is a bit premature but I bought it used and perhaps it had not been maintained as well as I was told.
26 days in the shop.Took 6 days to get the parts. Still not fixed. Hope to get it tomorrow. It sure has soured me on the dealer. I was considering a new Hustler or JD mower. I don't think I will ever buy anything from this bunch.
/ M65 zero turn drive problems #11
If it is the shop you bought it from, that is too long for sure. If not, a little bit more understandable.
If the shop is servicing farm equipment as well, then this is a busy time for a shop and if so, surprising they didn't fix you up with a loaner to help with mowing.
But then, we really don't know what has been going on.. hope it runs fine when you get it tomorrow.
27 days and the mower is back. It works perfectly. The cost of parts was over $1600 and total bill was a bit over 2 grand. Hurts, but things with motors will cost you at some point. Back to work.
10ft Cattle Panels (A64047)
10ft Cattle Panels...
2006 INTERNATIONAL 4300 24FT NON CDL BOX TRUCK (A59575)
2006 INTERNATIONAL...
CLASS 3150TC DISCO HAY BINE (A63290)
CLASS 3150TC DISCO...
2018 International HX620 Quint Dump (A62613)
2018 International...
STAINLESS STEEL BAKERS RACK (A63745)
STAINLESS STEEL...
JOHN DEERE 825 - 4R DANISH TINE CULTIVATOR (A63290)
JOHN DEERE 825 -...
