OP
wploetz
- Joined
- Jun 1, 2010
- Messages
- 152
- Location
- Dunkirk
- Tractor
- Mahindra 60HST 60HP Diesel Compact 4WD Hydrostatic with factory cab, A/C, radio
Thanks
I will check with my buddy at Midas
Looks like an ordinary drum brake used as a driveshaft brake. Fairly common back in the day.
Yes, you should be able to have the shoes relined and may want to have the drum turned on a brake lathe to clean it up.
Also looks like it's got a little grease or tranny lube in it, I'd check the seals to make sure the transmission isn't leaking into the brake.
