Vertical Exhaust
/ Vertical Exhaust #1
overstreetd
Bedford, VA
Ford 4610
My original exhaust system on my Ford 4610 is totally worn out. I want to replace it with a new one but want to convert to a vertical one. The bush hog loader makes it almost impossible to replace it as is. Are there kits to do this?
/ Vertical Exhaust #2
Can't you drop the loader off?
No idea if a kit is available, but once you get the loader off so you have better access, I think a little ingenuity will solve the problem...after all, tractor exhausts are pretty simple.
/ Vertical Exhaust
Thanks!. I'm really not equipped to take it off easily.
/ Vertical Exhaust #4
How about doing some custom work like I did with my TC24DA?
/ Vertical Exhaust #5
looks great but would worry i would snag it in the woods and that could be a problem. would be great great i the open country though and could also be a lightning rod. - hehehe for the last part... Great work. thanks for the idea. mine points downward and do not like it as the exhaust has a tendency to blow back upwards and is obnoxious.
2005 IC Corporation PB105 School Bus (A64194)
2005 IC...
MASSEY FERGUSON 240 TRACTOR (A64278)
MASSEY FERGUSON...
2019 Ford F-550 4x4 Altec AT40G 40ft. Insulated Bucket Truck (A64556)
2019 Ford F-550...
2023 BARRETO E30SGB WALK BEHIND STUMP GRINDER (A63276)
2023 BARRETO...
2009 Chevrolet Silverado 1500 4x4 Ext. Cab Pickup Truck (A64556)
2009 Chevrolet...
Wooden Glider Chair (A64557)
Wooden Glider...
