Tractor Vacation
/ Tractor Vacation #1
Loadstar
Evansville, IN
Ford 640
Packed up the family and the Massey and went to the lake house in Trigg county, Ky. Mowed some big grassy hill ground, some sapling covered hill ground, some flats, hedges just a little bit of everything. Shot off fireworks played with the family. Good weekend! Returned home with a mountain of broke shear bolts scattered on the rotary, also a desire for some front Massey weights. Front tires didn't get much wear being off the ground from hills and heavy vegetation. Had a great time with it, may have to take it on vacation to florida in a few weeks.
Hope everyone had a great 4th.
/ Tractor Vacation #2
Nice job! So, you have a lake house in Florida too?? I guess you learned to steer pretty good with the brakes, huh?
/ Tractor Vacation #3
Little tractor therapy always good every now and than.
/ Tractor Vacation
No house in florida.
I need a tougher rotary with a slip clutch
/ Tractor Vacation #5
Can you get shear bolts that have a smooth shank in the part where they are supposed to shear?
I don't think that having a thread at that location is helping with your troubles.
Also, not sure if you are aware of this, but the nut on the shear bolt should shouldn't be socked up tight or that will reduce its shear strength.
A nylock nut will stay put, even if it's left a little loose, and give you the full shear strength the shank is capable of.
/ Tractor Vacation #6
Thinking the same thing, you beat me to the post! Get bolts long enough no threads are in shear.
/ Tractor Vacation
Smooth shanks that I could get a hold of at the hardware store were too high of a grade. I will stock up on better grade 2 bolts. Locknuts take too long and cost more. I just snug the bolt a little not torque it down.
/ Tractor Vacation
Got to deal with what you can on the weekend in a area where you can't get much.
/ Tractor Vacation #10
One thing I found which helped me from shearing to many bolts was to keep the RPM up. At least 2000. The extra kinetic energy helps getting through rocks and branches.
2019 AUTOCAR XPEDITOR TRASH COMPACTOR TRUCK (A63276)
2019 AUTOCAR...
20 GALLON SPRAYER, 12V (A64278)
20 GALLON SPRAYER...
2022 Can-Am Defender Lone Star 4x4 Utility Cart (A64553)
2022 Can-Am...
2024 POLARIS GENERAL XP1000 RTV (A64278)
2024 POLARIS...
2006 Western Star 4900 Concrete Mixer U98358 (A62613)
2006 Western Star...
2022 EZ-GO ELITE...
