Your towing rigs and trailers
   / Your towing rigs and trailers #2,141
I think my clearance is ok. I had the trailer and truck perpendicular and then some to each other just the other day and no hitting. Haven't got out and looked just how close it is.
   / Your towing rigs and trailers #2,142
A couple of pics of My tow rig hauling some hay.
   / Your towing rigs and trailers #2,143
When you get a chance will you take pic of the bar setup holding your ramps. I need to do something like that to mine.
   / Your towing rigs and trailers #2,144
Sure will, I will try and get them for ya tomorrow. I drilled the ramps and the sides of the trailer and bolted in some cat. 1, 3ph lift pins and then welded them in place. Drilled some flat bar out to hold them up. I can now haul 17 rolls on a 30 foot trailer.
   / Your towing rigs and trailers #2,145
The clearance that I referred to, is over the tailgate. When the front of the truck goes down, the back comes up. If you drove across the terraced hay field were we used to live, the first terrace would dent your tailgate, then your truck would stop moving when the dovetail hit it, leaving the trailer axles in the air.
The same thing can happen on-road, like a steep driveway with a sharp breakover angle at the top.
This is the clearance on my rig.
431890-your-towing-rigs-trailers-p1260011-jpg
431889-your-towing-rigs-trailers-p1260001-jpg
And when it was new, 9/6/2006. :thumbsup:
431891-your-towing-rigs-trailers-p9062366-jpg
   / Your towing rigs and trailers #2,146
Since I purchased my trailer I have run into so many times that I needed it to be another foot longer but if I atleast have a ramp setup like yours I can eliminate some of the headache
   / Your towing rigs and trailers #2,147
Mine came with chains, so you can adjust the angle of the ramps and a 4' popup dovetail.
attachment.php
attachment.php
attachment.php
attachment.php
   / Your towing rigs and trailers #2,148
^^^ Interesting looking fence... combination of wood post and pipe... did you put it in?
   / Your towing rigs and trailers #2,149
Nope, too busy moving, had to keep the horses away from the house, barn and shop. We hired a local fence installer.
The rails are about 15' long and slide together,
431931-your-towing-rigs-trailers-p5290012-jpg
431932-your-towing-rigs-trailers-p5290017-jpg
431933-your-towing-rigs-trailers-p5290023-jpg
431934-your-towing-rigs-trailers-p6140100-jpg
431935-your-towing-rigs-trailers-p6140101-jpg
   / Your towing rigs and trailers #2,150
Very nice! That's a 20' PJ right? I've seen it in other posts? How has it been doing? Any complaints? Thinking about getting one. I like the deck over.
Did you ever get that deckover? I have been looking at one but just have not pulled the trigger. what I have been looking for would be like a rollback wrecker but on a trailer. may have to settle on a deckover tilt with a winch.
2017 Ford F-750 Crew Cab Terex Hi-Ranger 6TC65 65ft Insulated Bucket Truck (A55852)
2017 Ford F-750...
2017 TROXEL 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2017 TROXEL 150...
UNUSED FUTURE GR87-87" HYD GRADER BLADE (A57193)
UNUSED FUTURE...
2022 Polaris Ranger Utility Cart (A55787)
2022 Polaris...
2019 Caterpillar DP35N 7,000lb Diesel Forklift (A55851)
2019 Caterpillar...
UNUSED 1RANCH 1RIG-13' 14' BI-PARTING IRON GATE (A57193)
UNUSED 1RANCH...
