Farmall A clutch problem - help!
   / Farmall A clutch problem - help! #1
txdon
Super Star Member
Central Texas
Kubota M6H-101
My 1947 Farmall A was working fine a month ago and started right up today but when I went to put it in gear it would just grind and I could not put it in gear. When the motor is off I can shift it into each gear with the clutch depressed. I fear major clutch problems but maybe just an adjustment. Can anyone help me troubleshoot and fix this clutch problem? Thanks.
   / Farmall A clutch problem - help! #2
Sounds like you clutch disk has stuck to the flywheel or pressure plate. put it in gear and depress the clutch and tryto start it. it might break loose. If that don't work start it in neutral and warn it up. then shut it off and place it in first gear. then start it up in gear and drive around with the clutch pedal depressed and it might come free. if that don't work the tractor will need to come apart and see whats wrong. You might adjust the clutch release rod however I don't think that's you problem.
I'll try that tomorrow, thanks. How do you adjust the clutch release rod?
That did it works fine now, Thanks! Mowed for two hours this morning!
   / Farmall A clutch problem - help! #5
Glad I could help. Of course as old as I am ive been there done that a couple of times. some folks will use a block of wood wedged so as to hold the clutch released when storing a tractor.
Thanks for the tip - I'll start doing that.
   / Farmall A clutch problem - help! #7
Right on. I used blocks on all my tractors to prevent clutch sticking problems.
My 2 year old great nephew came up to me today and asked to drive the "little red tractor" I said sure, and he gave me the biggest hug. After that he stood on the platform and I sat in the seat behind him driving around for an hour in first gear. He went home with a big smile on his face - a future TBN member. Little did he realize the tractor belonged to his Great Great Grandfather.
   / Farmall A clutch problem - help! #9
My B2910 Kubota came with a little block of wood to stick in the clutch linkage to keep clutch from rusting to plate. Things haven't in all these years.
   / Farmall A clutch problem - help! #10
Yep start them young. My grandson Chris is just a biting at the bits to start playing with grandpaws toys. he is 20 months old. and don't like to watch TV He wants to go outside. and crawl on everything and make engine noises.
2015 Dodge Challenger Coupe (A50324)
2015 Dodge...
2016 VOLVO VNL300 TANDEM AXLE DAY CAB (A51222)
2016 VOLVO VNL300...
2020 VOLVO VNL760 SLEEPER (A51222)
2020 VOLVO VNL760...
2006 KENWORTH T300 SERVICE TRUCK (A51243)
2006 KENWORTH T300...
2011 BMW 5 Series 550I GT Sedan (A50324)
2011 BMW 5 Series...
CATERPILLAR 299D SKID STEER (A51242)
CATERPILLAR 299D...
