Wheel weight
/ Wheel weight #22
I MUCH prefer radial tires on my tractors and putting fluid in radial tires greatly defeats the traction advantages of radial tractor tires.
SR
/ Wheel weight #23
A 55 gal drum of concrete t just isn't heavy enough. I put fluid in my tires, 2 95lb wheel weights and a 1700lb block of concrete off the 3pt and I could still make the rear end light.
/ Wheel weight
For loader work ballast, how about a drum full of concrete with a 3 point hookup on it?
3 pt. weight ballast - $125
3 pt weight ballast is your best bang for the buck for FEL work. I used a rear scraper blade until I got my wheel weights made, but trying to turn around in between trees I was like a bull in a china closet. I really like not having anything sticking out to worry about when I'm in the woods.
/ Wheel weight
WOW! That's one heckuva bucket full!
/ Wheel weight #26
It sure is. A 78" HD jd bucket on a 563 nsl loader full of wet clay. My front tires have taken a beating in the shale that I had been moving. I'm def going wi th heavier ply radials when these won't hold air anymore. I think I'm going to have to make a heavier steel weight since I snapped the cat 1 bar that was in the weight this winter. I'm going to shoot for 2500lbs this time.
2016 Deere 180G (A60462)
2016 Deere 180G...
2022 CASE TV450B SKID STEER (A64279)
2022 CASE TV450B...
2006 Freightliner M2 106 24ft. Box Truck (A61573)
2006 Freightliner...
2016 Nissan Titan XD 4x4 Crew Cab Pickup Truck (A61573)
2016 Nissan Titan...
2026 Electric Tricycle (A64194)
2026 Electric...
1996 Sunflower 1543-38 Folding Disk (A63688)
1996 Sunflower...
