Home-made mini tractor 4*4 with the joint joined frame
   / Home-made mini tractor 4*4 with the joint joined frame
After a heavy rain.
   / Home-made mini tractor 4*4 with the joint joined frame #132
That is an interesting walk-behind tiller you have Vladimir - it covers a large area quickly.
Regards, Dave.
   / Home-made mini tractor 4*4 with the joint joined frame #134
I like the videos. You need to add another seat for 2 dogs. :)
   / Home-made mini tractor 4*4 with the joint joined frame #136
Thats a really nice tractor. Some tractor manufacturers should take note.
   / Home-made mini tractor 4*4 with the joint joined frame #138
You should make the tiller hook up to the tractor. Then you could have allot better control
Land of the slope, the tractor will spread.
Cleaning the grass on a field of melons
Clemco 150psi Portable Sand Blasting Machine (A55973)
Clemco 150psi...
UNUSED FUTURE SB45 HYD SILENT BREAKER (A52706)
UNUSED FUTURE SB45...
MILWAUKEE 14" Abrasive Cut-Off Machine (A59076)
MILWAUKEE 14"...
2015 Ford F-350 4x4 Pickup Truck (A54814)
2015 Ford F-350...
SKIDDED FRAC TANK (A55745)
SKIDDED FRAC TANK...
2011 Isuzu NPR 14FT Box Truck (A56858)
2011 Isuzu NPR...
