Battery not staying charged
/ Battery not staying charged #1
KubotaM7060
Chapin
Kubota M7060
We have an old yanmar 2500 Diesel tractor for our hunt club and the battery will not stay charged. We have replaced battery, alternator, regulator...you name it. We are replacing the switch is going to be replaced Saturday and after that I dont know what else it can be.. Anybody experienced this?
/ Battery not staying charged #2
Don't know how to solve your particular issue and it seems you tried a bunch of stuff.
There must be some drainage somewhere.
Here is a fix that has worked for me..... a battery disconnect.
Good luck
where did you install that at?
where did you purchase that at?
/ Battery not staying charged #5
Don't remember where it's been so long ago.
But any auto parts, marine or tractor supply should carry it or something similar to it.
/ Battery not staying charged #7
Some simple checks with a voltmeter will isolate your problem. You should have done that in the first place prior to changing parts that may be good.
/ Battery not staying charged #8
True enough, BUT you have to remember most people have more experience handling venomous reptiles than voltmeters, which is to say none. It is not taught in school you know. Unless you pick up that skill along the way in life, you are not going to know how to use either the analog or digital models nor make the deductions involving Ohm's law, or scientific method in isolation and trouble shooting. Just what do they teach in school anyway? So in general I agree with you, but how does a person gain this knowledge?. For some it is a hard road like this fellow has been down.
/ Battery not staying charged #9
Years ago I bought a used Ford Probe for my daughter as her first car. A couple days after we bought it the battery died. I checked the alternator and it seemed ok so we just replaced the battery. Couple days later that one was dead. I changed the alternator in case it had an issue but still that car would drain the battery. I took it in to a dealer and they said the alternator was bad. Don't recall how it worked out but we were in twice more. Eventually they said it must have a short some place discharging the battery... The service guy suggested I trade it in because they would never find the problem with all the potential wires that could be bad on a car.
We did trade it but being fairly car savy that always bugged me that I could not fix it.
Could be you have a short some place on a circuit that does not kill power when the key is off.
Bill
/ Battery not staying charged #10
Some trouble-shooting probably could have saved you some money. That said, I had a car that would run the battery down in about two days. If the car were driven daily, there was no problem. I knew there was some drain, but for the life of me I could not find it. Then one night I saw a faint light coming from the tail lights. The trunk light was staying on all the time. I removed the bulb and never had another problem.
Obviously not a solution to your problem, but I bet it is something similar.
/ Battery not staying charged #11
What do your volt/ohm meter readings tell you?
/ Battery not staying charged #12
These tractors are way simpler than a car, even an older Probe. You could run all new wires and almost be faster than trying to find a problem. But honsestly i think i would just install a batery disconnect if you use it say 6 times a year. Just pull hood and connect it back.
You can get those on Ebay, amazon or any store like advance auto part or autozone.
/ Battery not staying charged #13
Are you really saying that no-one at your hunt club knows how to operate a volt/ohm meter?
/ Battery not staying charged #14
I'm starting to wonder if anyone actually checked the Battery when it wouldn't start. No mention that it's has at least 12V. after it' been sitting that I recall. I've Had them go bad Quick before. I would also pull fuses and check the volts. May find it after it sat overnight.
/ Battery not staying charged #15
You have me mixed up with the original poster. I have been using test equipment for about 50 years now. And trouble shooting electrical/electronic circuits. AND using the scientific method to isolate and resolve faults . I was just commenting on our educational system , and lack of coverage of such topics .:)
/ Battery not staying charged #16
Alternators use diodes to rectify the output.
Could be as simple as a shot diode, but then there are all sorts of other possibilities.
Install a battery disconnect switch, About $10.00 or so.
/ Battery not staying charged #17
/ Battery not staying charged #18
And a New Alternator. It's going bad and won't last long if that's the problem.
/ Battery not staying charged #19
YES. ... Otherwise, just change the tractor.
4R CHISEL RIPPER BEDDER (A63291)
4R CHISEL RIPPER...
Attention (A57148)
Attention (A57148)
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
Informational Lot - Financing (A63688)
Informational Lot...
UNUSED WOLVERINE HYD GRAPPLE BUCKET (A64281)
UNUSED WOLVERINE...
2012 VOLVO DBL SLEEPER ROAD TRACTOR (A62130)
2012 VOLVO DBL...
