Mixed Metals welding
/ Mixed Metals welding #1
woodlandfarms
Super Member
Los Angeles / SW Washington
PowerTrac 1850, Kubota RTV x900
OK, so hang tough here guys, I have an art project that is on the honeydo list. I will need to weld Stainless to Copper (or braze, or solder). It is not structural, but will be exposed to the elements. Oh, and then the stainless probably needs to be welded to regular soft iron.
Thoughts?
/ Mixed Metals welding #2
I've used regular solid copper electrical house wire as a filler rod (tig).
I used it for color effect (multiple passes) and for electrical contact points on my "third hand" tool so there wouldn't be black arc marks on aluminum.
It works very well and behaves pretty predictably.
For artistic welding stainless to steel to copper, I'd sure give it a go :)
/ Mixed Metals welding #3
If you have a tig the the last post is prob the best way
If not the i would use silver solder for the stainless to copper and mig the stainless to mild standard mild steel consumables work just fine
/ Mixed Metals welding #4
Never done copper to stainless. I'm watching this one.
/ Mixed Metals welding #5
You can use a silver bearing low temp solder ( 430 degrees melting ) and a propane torch if you wand a strong joint without the high temps of silver solder. Look at Harris Stay-Brite. Also may try Silicon Bronze with Argon for mig or tig. Copper filler sounds interesting as well. Never tried it.
/ Mixed Metals welding #6
My expertise is definitely not welding... but I think the silver ought to work fine for stainless to copper. Silver is often used as a wear coating on stainless steel (i.e. bolt threads). I recently MIG welded stainless drill rod to mild steel with no problem using mild steel consumables and 75/25 gas... better outcome that I expected. Since it sounds that you aren't needing a highly stressed finished product, this is what I would do.
/ Mixed Metals welding #8
post picts
I made a couple of quick release pins. Bent up some 3/16in mild steel rod and welded to 9/16in stainless drill rod to make quick release pins. Sorry can't see the welds... Already coated the handles with a couple coats of plastic dip. image-1316811219.jpg
/ Mixed Metals welding #9
Stainless to mild steel is no issues at all. Bout anything you would use for welding rod or wire will work for what you want.
Copper to steel or SS is the issue. I think the only options have already been mentioned. Solder or tig
/ Mixed Metals welding #10
Thoughts?
You do not mention what type welding/soldering equipment you have available. That would help with the ideas. There are manual arc rods if TIG and MIG are not your thing like me. I use silver solder a lot, also bronze welding rod with OA. Propane for SS has too large a flame cone for my liking. For SS/Bronze torch work on art stuff (which I don't do) I would think a very small tip is the ticket.
Ron
I have an oxy acet setup, a lincoln 180C mig and an Everlast stick.
I have an aluminum spool gun for my lincoln but have yet to fire it up, and am contemplating a simple tig unit for the everlast stick.
I also have the standard soldering iron pencil and gun version.
/ Mixed Metals welding #12
JB WELD
/ Mixed Metals welding #15
With OA I would either silver or bronze braze your light art materials. You may need to practice some to develop the tip size and heat spread that works best for the materials you are using. Heavier (3/16) their are good manual arc rods for SS to CS. Your local welding store can help you select the right SS alloy rod. They work very well with the right Amp setting. I would not use 6010 or 6011; chose the right SS rod. there are also some copper allot arc rods by Eutectic, look it up on the web and get your welding supplier to order as they are normally not stocked unless there is a local demand.
Ron
Ron
/ Mixed Metals welding #16
How did this turn out? I have never welded copper. I have soldered and brazed plenty but never welded it. When brazing copper to steel I always use silver and tend to keep more heat on the steel. Stainless to steel is no issue as mentioned. I generally use 309L TIG wire for it. If you are doing something real thin and know someone with 309 MIG wire you can use it to TIG with also instead of purchasing it.
/ Mixed Metals welding #18
keep us updated when you do it.
GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A67714)
GENERAC MOBILE...
PALLET OF HOSE REELS (A68842)
PALLET OF HOSE...
2003 30ft Rinker Captiva Boat w 2017 30ft Tri-Axle HMDE Boat Trailer (A66738)
2003 30ft Rinker...
2006 Western Star 4900 Concrete Mixer U98352 (A62613)
2006 Western Star...
2014 CHEVROLET CAPRICE POLICE CAR (A66091)
2014 CHEVROLET...
More info coming soon. (A64557)
More info coming...
