Exploded diagram for Vicker pump off Ford NAA
/ Exploded diagram for Vicker pump off Ford NAA
I called Attica...over $800 with a $372 dollar core....My local guy is looking with his suppliers and thought he could get a pump for around $150.00. Mean time I put it together with the new seal and front bearing It is installed on the tractor and is running. Loader cycles just fine. It still can lift the front end of the tractor off the ground. Seal is dry and all my refit plumbing looks good too. I did find that the filter housing was mounted backwards from the direction of the arrow so I reconfigured things make the flow follow the arrow.
/ Exploded diagram for Vicker pump off Ford NAA #22
so, i have this same pump on my ford.....the center housing cracked on both sides after adding new hoses and oil to the reservoir. did i mess up by not letting the air out before i started the engine?
any ideas plus a source for the housing would be greatly appreciated.
many thanks,
guil
Not sure where you are but my guy is mdm hydraulics in salem oregon. Also try surplus center for replacement pumps.
/ Exploded diagram for Vicker pump off Ford NAA #24
so, i have this same pump on my ford.....the center housing cracked on both sides after adding new hoses and oil to the reservoir. did i mess up by not letting the air out before i started the engine?l
Those housings break only from a severe pressure spike, usually from deadheading the pump.......better check your hose connections before you fire that up again or you may need another housing after
Air purges itself through start up and ends up in the reservoir......also don't forget to clean the suction screen at the tank
/ Exploded diagram for Vicker pump off Ford NAA #25
Many thanks for the response! I have spoken to your guy in Salem and may send the pump to him. What's the salvage center?
cheers,
guil
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
2016 Deere 180G (A60462)
2016 Deere 180G...
2019 International WorkStar 7300 4x4 Altec AA55 56ft. Insulated Bucket Truck (A60460)
2019 International...
2022 EZ-GO ELITE...
Kubota Blade (A64126)
2003 Dodge Ram 4x4 Ext. Cab Pickup Truck (A59230)
2003 Dodge Ram 4x4...
