JD LX 176 14HP Kohler problem
/ JD LX 176 14HP Kohler problem #1
chazdo2
auburn new york
walk behing power drive 21
I got a basket case mower to repair for a friend. I think this was not the original motor. I cant find the pulse port for the fuel pump. I have been using the port off the valve cover. I doubt this is the right one because I believe it goes to the air cleaner. Any help greatly appreciated.
/ JD LX 176 14HP Kohler problem #2
Is that a K series engine??
Not sure on the 14 hp kohlers but the K301 12 hp i just worked on has a cam driven mechanical pump and pretty sure All K series are this way
Also some were built with just a cover over the fuel pump mount point.
/ JD LX 176 14HP Kohler problem #3
I think you are correct about this not being the original motor. I had a LX 176 and it had the Kawasaki engine.
KBH Tender Trailer (A63118)
KBH Tender Trailer...
3PT CARRY ALL (A63290)
John Deere XUV 835R (A62183)
John Deere XUV...
(4) Rolls of Barb Wire (A62183)
(4) Rolls of Barb...
2015 Freightliner CA113 (A62180)
2015 Freightliner...
2017 FORD F-350 XL 35' NON-INSULATED BUCKET TRK (A59823)
2017 FORD F-350 XL...
