Kubota B2650 and B3350 info and hints
/ Kubota B2650 and B3350 info and hints
Well, DUH!!
I read the destructions and knew to go to idle before engaging the PTO on my B3350. What I didn't realize is that the *speed* with which the PTO handle is lowered also affects the way the clutch operates. If you just dump the handle down, as I was doing, the engagement is abrupt and this is rather apparent when using a rear brush cutter. Lower the handle a bit more gently and things smooth out significantly, just like the clutch on a manual tranny.
I have no idea why sometimes the simplest things escape me :c)
/ Kubota B2650 and B3350 info and hints #192
Can I use "Red" off road diesel with the B3350. I want to make sure not to add any issues to the regin process.
/ Kubota B2650 and B3350 info and hints #193
I am thinking that as long as it is low sulfur you should be OK
/ Kubota B2650 and B3350 info and hints #194
You should be just fine as the red color is just a dye in the same exact fuel .
I'm pretty sure, at least in the USA, that "low sulfur" has been replaced with "ultra low sulfur" which is 15 ppm (parts per million) or less for both road and off road use. My B3350 specs ultra low sulfur only.
/ Kubota B2650 and B3350 info and hints #196
Thanks for the replies. I have a bulk tank of red so we will see what happens. My wife mowed yesterday and I will have to check the hour meter but it sure likes Diesel. Also hydraulics oil when your dealer doesn't tighten the fittings.
Finally got around to checking the hydraulic pressure on my B3350. The WSM says it should be 2400 to 2450 psi. Mine was set at 2050. No wonder the BH77 backhoe was a little anemic. Removed the loader relief valve and it had three shim washers totaling 3.21 mm thickness. I added two washers to add 1.90 mm and that raised the pressure to 2500 psi (close enough for gauge error). While I was at it, I put the test gauge on the power beyond and checked the pressure while operating the hoe, also 2500 psi now, so the loader relief valves must be set higher than that. Anyway, looking forward to removing some tree stumps, should work a lot better now.
bumper
Been quite.
I was out mowing a couple of acres with brush cutter with air conditioner on. The cab started to get warmer. Back in the tractor shed I measured the output of the AC at only 12 degrees below ambient. I had previously cleaned the screens and the radiators "looked" clean. However, upon closer inspection, I found the AC radiator clogged up completely in the area behind the battery. The material clogging the radiator was light gray and not visible unless the battery was swung out of the way and a light shone behind (between) the radiators. I could swing the battery far enough out without removing battery terminals, so this area is going to get better cleaned in the future. I plan on making a side squirting water spray wand to get in there.
This is a piss poor design feature. I was thinking of adding a thermostatically controlled fan on the front of the AC radiator, as there is no shroud to help pull air through this directly. Can't find a fan thin enough and there is very little room to fabricate a bracket to position an aux fan. The shroud would also be a poor idea as it would restrict flow into the main radiator from the sides etc. I'm still noodling on all this, but I really would like to add a fan to improve AC efficiency.
One possibility is to make more room for the fan by switching to a physically smaller battery - - a LiFePO4 may well work without giving much up in battery capacity.
/ Kubota B2650 and B3350 info and hints #199
20150906_211600.jpg20150906_211726.jpg20150906_211618.jpg20150906_212045.jpg20150906_211536.jpg20150906_211528.jpg
/ Kubota B2650 and B3350 info and hints #200
Attached thumbnail is no lights, last pic is front light bar on. Third is of rear light bar. Will have plenty of light as the days keep getting shorter
2013 FREIGHTLINER CASCADIA (A60736)
2013 FREIGHTLINER...
GEARMATIC WINCH CABLE DRUM (A58214)
GEARMATIC WINCH...
2026 Kearney 102"x36' Gooseneck (A60462)
2026 Kearney...
207273 (A52708)
207273 (A52708)
2012 HINO 268A 4X2  26FT NON CDL BOX TRUCK (A59906)
2012 HINO 268A 4X2...
2017 John Deere 5090GN (A53317)
2017 John Deere...
