TRIVA FUN
/ TRIVA FUN #945
There was a version of the P-51 that got as far as a wind tunnel test model. It had a mid engine and a swept wing.
What else was novel about it?
Bruce
Swept forward wing.
Eclectic Aviation - P-51 Mustang
Bruce
/ TRIVA FUN
Maybe the atomic bomb? just guessing.
Good guess.
50 to 70 miles north of Vegas the gov was conducting "A" bomb tests.
They could be seen in & felt in Vegas.
The hirer up the better the view & more of the shock wave could be felt.
No guesses on the beast that use or may still roam the desert near Gila Bend AZ???
/ TRIVA FUN #947
Sasquatch?
Bruce
/ TRIVA FUN #949
Not a camel? I recall the Army experimented with using them, and some managed to escape and run wild.
/ TRIVA FUN
You are correct, but if memory is correct the Army turned them loose as they did not work out very well.
A little more on trains.
Traction engines were only used on narrow gauge R/R'S. How narrow did the narrow gauge R/R get??
Modern diesel electric works on a similar principle. Brand name think "Shay".
steel wheels on steel rails does not provide very good traction. Gets worse if wet in ice conditions.
What did trains do to help over come the friction problem????
/ TRIVA FUN #952
They were still using steam engines in this part of the country when I was a kid in the 50's. My Dad ran a sand plant and we lived near by. I can still recall the sound the old engines made when they broke traction under a heavy load. I could sleep through all of the switching and such, but I always woke up when they broke traction.
/ TRIVA FUN #953
The geared locos were used mostly on narrow gauage logging RRs due to the steep grades.
Locos carried a tank of sand with nozzles pointed at the tracks just ahead of the driving wheels.
Harry K
/ TRIVA FUN #954
Maybe it has been posted but how many gallons of water does one inch of rainfall produce over one acre?
/ TRIVA FUN #955
It will take a "Beautiful Mind" to quote that from memory. I had NEVER heard that figure quoted, so I had to look it up. I suppose you could convert one acre-inch of snow, in gallons to an acre-inch of water. :D
/ TRIVA FUN #957
Harry K
The sand box was usually located on the top of the boiler to facilitate easy loading and keep it from freezing.
/ TRIVA FUN #958
We have a winner.
Isn't that an astounding number? ONE inch of rain is 27,154 gallons per acre. No wonder my garden likes natural rainfall so much. It's just a whole bunch more.
/ TRIVA FUN #959
How did the "monkey wrench" get it's name?
/ TRIVA FUN #960
If you start with a penny and double the total every day for a month, how much money do you wind up with?
a) $26,210
b) $262,100
c) over a million dollars
Tire Balancer (A61570)
1605 (A57192)
1605 (A57192)
Paladin Dirt Sifter (A61166)
Paladin Dirt...
2015 FORD F-150 LARIAT CREW CAB TRUCK (A59823)
2015 FORD F-150...
1988 Lufkin CM-320D-305-100 Road Runner Mobile T/A Oil Field Pumpjack (A60352)
1988 Lufkin...
500BBL WHEELED...
