TRIVA FUN
/ TRIVA FUN #902
I remember reading about the first steam train that broke 100 mph. They used a flat straight stretch of track out in the plains somewhere, probably Kansas and a stop watch as they passed the mile posts.
The Flying Scotsman became the first steam locomotive to exceed 100mph while travelling between Edinburgh and London on November 30 1934.
/ TRIVA FUN #904
From Fastest Steam Locomotive
New York Central & Hudson River 4-4-0 No. 999 continued
Background
NYC #999 is one of the world's most famous steam locos. Built in 1893 for New York Central's "Manhattan-Albany-Buffalo Empire State Express" it was one of 62 locos at Chicago's Columbian Exposition. It's claim to fame and the reason it has been preserved, (Chicago Science & Transportation Museum), was because of a May 1893 run between Rochester and Buffalo, NY. On that run it is said to have become the fastest machine of it's time, reaching 112.5 mph between Batavia and Corfu.
What are the facts concerning this high speed journey?
It is over a 100 years since this run, and no detailed timing details have been found. However such details must have been made as a 1976 article by John F Clay states there were 2 experienced observers on board. The practice of taking detailed passing times to the nearest second and stopwatching between quarter mile posts had started around a decade earlier, and formed the basis of accurate train timing that has survived from the late 19th Century, through the 20th Century and into the 21st Century.
But back in May 1893 there was another group of "train timers" travelling behind No. 999. Railway Officials and Newspaper Reporters. Not two groups of people who are likely to have studied or understood the mechanics of putting together a very detailed and accurate log of a train journey, including recording it's maximum speed. It must certainly have been this group of people, probably taking random times without any other detailed substantiation, who recorded the 112.5 mph. It certainly wasn't the two experienced train timers who recorded such a high maximum speed. They recorded a maximum of 81.5 mph, which is almost certainly very close to what was reached that day. It is reported that some time later the high speed attempt was repeated to prove it was possible, and the maximum speed recorded on this second run was again near to 81 mph.
Did NYC 4-4-0 No. 999 reach or exceed 100 mph?
The reality of that day in May 1893 was that the 4-4-0 went no faster than around 82 mph. No expert on steam locomotive performance recording has ever given any credence to a higher maximum speed. Only massive errors by people on the day who may well have had no experience at all of proper train timing, (or speed timing of any type), lead to the over 100 mph claim being made. And those people included newspaper reporters, so the highly inaccurate speed would have been given immediate widespread publicity, creating the "legend", and eventually leading to the preservation of NYC No. 999.
/ TRIVA FUN #905
Nope!! Not New Mexico or Oklahoma but good guesses.
More info. They had to fly in 60-60 conditions.
Similar story about islands on the Aleutian chain although there was no telephone pole mentioned.
Never heard the "60-60 conditions". Explanation? I assume very bad weather. That for sure applied to the Aleutians. I was stationed way out near the end (Shemya) in 1956.
Harry K
/ TRIVA FUN #906
We sure have hit on a number of different topics here on this thread. Lets see if this generates any interest.
A standard automotive turn signal bulb an 1156, consumes about 27 watts of power, The earth is pretty much a sphere. VHF and UHF radio waves usually (note I said usually) travel in more or less straight lines. That means if you are not in line with one of these signals, they usually just propagate from the transmitter antenna out into outer space and keep on going.
But HF radio waves (These are waves from 3 to 30 Megahertz in frequency) often can be propagated for thousands of miles. You can easily send a digital HF signal from where I live here in Missouri to countries in Europe with just 1 watt of power.
If you used as much as the 27 watts (like the automotive lamp) a voice signal could easily be transmitted and received at that distance as well. Sometimes with much less power, sometimes much more is needed.
What is the mechanism at work here that allows these signals to cross oceans and continents without just flying off into outer space?.
/ TRIVA FUN #907
I'll have to reflect on that question.
Bruce
/ TRIVA FUN #913
Earth's magnetic field.
The Mag field can have effects, but the main driver of ionization is the sun. Every day it pumps energy into the particles and ionizes them into layers. One could spend a lifetime reading about and trying to understand all of this mechanism and its effects, but the simple answer is our star the sun causes these effects to happen. We humans have been using this phenomena to good effect for a not quite a 100 years now.!
In the early days of radio it was felt by the radio professionals that the HF (High Frequency) portion of the radio spectrum was useless so it was given in its entirety to the early Amateur radio operators. it did not take them long to fix that error.:)
While HF radio might not be quite as valuable today as it was a few years ago now that we have many communications satellites, and a whole lot of fiber optic cable crisscrossing all continents and the oceans, it is still pretty useful. AND it works without infrastructure. Just a radio and antenna on one end and a radio and antenna on the other end and sources of power for both.. Nothing in the middle to break, be sabotaged or be traffic congested.
/ TRIVA FUN #914
Harry K
Well 60-60 stands for 60 mph cross winds at - 60 degrees Fahrenheit. The base known for this is in Minot North Dakota.
Minot Air Force Base - Home
/ TRIVA FUN
A little more on trains.
What is a traction engine???
/ TRIVA FUN #917
Often used for an electric locomotive, powered by overhead wire or 3rd rail.
Also a steam powered farm tractor.
Bruce
/ TRIVA FUN
Bruce
Not talking something modern. Old time steam trains.
/ TRIVA FUN #919
Moved by friction of powered wheels on rail, not rack, gear, or cog.
Bruce
/ TRIVA FUN #920
When did Chevrolet first introduce the V8 engine in its line of production automobiles?
2023 CATERPILLAR 262D3 SKID STEER (A64279)
2023 CATERPILLAR...
2018 FREIGHTLINER M2 4X2 S/A 26FT NON CDL BOX TRUCK (A59911)
2018 FREIGHTLINER...
2022 EZ-GO ELITE...
2011 Ford E-350 Passenger Van (A61573)
2011 Ford E-350...
2017 International HX620 Quint Dump (A62613)
2017 International...
PALLET OF MISC METAL (A63291)
PALLET OF MISC...
