Kubota easter eggs- Fuel tank full notification
/ Kubota easter eggs- Fuel tank full notification #1
BTDT2
Grand Lake Oklahoma
Kubota 4240HSTC
Am I the only dummy that didn't know that if you leave the ignition key on while filling the fuel tank on a Grand L, it will starting beeping when you are 3/4's full, and change to a continuous beep when the tank reaches the full mark?:cool2:
Anybody else have some Kubota easter eggs?
/ Kubota easter eggs- Fuel tank full notification #2
Re: Kubota easter egg- Fuel tank full notification
Wow, that is nice, I overflow my L45 all the time because the fill nozzle is at such an angle that once you see fuel, you immediately see fuel running out.
/ Kubota easter eggs- Fuel tank full notification #3
I had seen it in the owner's manual for my previous L3240 and my present L45 also does it.
/ Kubota easter eggs- Fuel tank full notification #4
Duh--I had no idea either. I wonder how many models this covers.
/ Kubota easter eggs- Fuel tank full notification #5
/ Kubota easter eggs- Fuel tank full notification #6
I didn't know it either. I also read owners manual, but missed that feature. Today I fueled my L4740 with the key on, sure enough it beeped as posted. Thanks for the information.
/ Kubota easter eggs- Fuel tank full notification #7
I am pretty good about reading my owners manuals but missed this.
I don't think it is mentioned in the manual for the L45 but I do remember reading about it in the manual for the L3240.I figured the L45 would do it because it shares a lot of features with the Grand L's so I tried it to see.
/ Kubota easter eggs- Fuel tank full notification #8
I did not know that. I will need to try it on the L4060 next fueling. Or I could read the manual some time
/ Kubota easter eggs- Fuel tank full notification #9
Will have to try this on the L45, you are correct that neck makes it hard to see fuel level.
I read the manual when I purchased the tractor but missed this one. I was looking for the front axle lube capacity when I stumbled on to it. No more standing on the tire looking into the tank while filling
I suspect everyone but me has figured this out, but in the past I have removed the front a/c condenser screen when mowing high grass, and used a whisk broom to clean it. It wasn't until my last oil change that I realized if you remove the right side engine access panel there is second removable screen that totally covers the radiator. Now I clean both of them when I see engine temp starting to rise.
2020 MACK GRANITE (A60736)
2020 MACK GRANITE...
(2) Goodyear 16.9R26 Tires w/ Rims (A60463)
(2) Goodyear...
2025 MMS MS36C (A60463)
2025 MMS MS36C...
(4) Dura Trench Drain Grates (A60463)
(4) Dura Trench...
2007 FRAC TANK 500BBL WHEELED (A60736)
2007 FRAC TANK...
2017 Komatsu PC138USLC (A60462)
2017 Komatsu...
