L111 won't run
/ L111 won't run #1
leaky little red
Ft. Collins CO
Massey Fergesun 135, Mahindra 5010 gear with fel and backhoe
Any of you guys or gals have a JD L111 Automatic? Mine will run for about half an hour and then it starts to stumble. shut off the mower, throttle back, choke on, and it dies. It will start with the choke on, but doesn't continue to run:mad:. I'm no mechanic, but I don't think it is vapor locking. I pulled the fuel line off at what I think is a fuel pump (between the filter and the round black thing before the air intake) and all the fuel drained back to the tank. Now it isn't filling back up again, but the mower started after a little cranking. Any Ideas?
/ L111 won't run #2
Check the tiny vent hole in your fuel cap. If it's blocked/plugged, a vacuum can build in the tank as time passes and choke off fuel flow. This part of what you have to say leads me to think that may be your problem: "Mine will run for about half an hour and then it starts to stumble."
/ L111 won't run
I will check that in the morning,
Thanks Bruce,
Bruce. whoda thunkit? :thumbsup:
/ L111 won't run
That tiny vent hole must be plugged, I couldn't even see it. When I mowed with it yesterday it started to stall, so I got off, took off the cap, put it back on, and away we went. New cap?
/ L111 won't run #5
Sure ---- cheap fix. But the vent hole is there ---- can you see it from the underside?? For no money at all you can just run it with the cap a little loose.
/ L111 won't run
It is more fun to jump off every so often, makes the neighbors wonder what the crazy guy next door is doing now:laughing:
Kuhn FC400RG (A60462)
330 GALLON POLY TOTE W/ CAGE (A62131)
330 GALLON POLY...
2016 FORD TRANSIT T250 CARGO VAN (A59905)
2016 FORD TRANSIT...
UNUSED KJ 23'X22' DBL GARAGE METAL SHED (A62131)
UNUSED KJ 23'X22'...
2018 Ram 1500 Reefer Meal Delivery Truck (A61568)
2018 Ram 1500...
UNUSED RAYTREE RMBD50-50" HYD DRUM MULCHER (A62131)
UNUSED RAYTREE...
