New Kioti Owner
/ New Kioti Owner
Your loader experience is different than mine. I got it off in about 5 min, drove it around a little to see what it was like, and then tried to put it back on. lined up good, hydraulics good, but then it was half an hour of fiddling with the joystick to get the pins to go back in:smiley_aafz: I don't take it off now, but don't really need to as I'm either using the loader, or mowing the woods or field, no close in work. Light isn't a problem since I have 2 forward facing ROPS mounted LED work lights that make a HUGE difference in night visibility.
When putting the loader back on, even on the perfectly even slab, I still needed to tap the pins back in with my trusty dead blow hammer. Nothing too crazy but I basically tapped the first side in with only slight pressure, then adjusted loader until the other side looked good, and still had to give the 2nd side a good couple of whacks to drive the pin in completely.
ROPS mounted LED lights is something I intend to add. Can I ask which ones you are using? Did you add them yourself or have them dealer installed?
/ New Kioti Owner #22
Never having done this before, so it may be a silly question; what is the process for disconnecting/reconnecting the hoses? Any need to bleed the system after? Does fluid end up leaking out when disconnecting?
/ New Kioti Owner
No need to bleed when reconnecting. Absolutely dry when I took it off (they tell you to wiggle the control to drain fluid after turning off engine and before removing quick disconnect hoses). I had a small bit of fluid come out of 1 or 2 hoses as I reconnected them. Quick wipe was enough get the drops. I'd say it was more my fault because I head the sleeve back longer that I should have when seating the hose.
/ New Kioti Owner #24
just a few drops lost if that..No bleeding needed. Just remember to shut off engine then sit there for 20 seconds. moving the joystick to all positions multiple times. This lets the loader and bucket "settle". Then pull up close. Shut down and hook up.
/ New Kioti Owner #25
Did them myself. I actually have 3, 2 on the ROPS forward, 1 rear facing next to the SMV and toolbox. I got fancy and wired all 3 with a switch on the dash, you could easily do a switch on the back by the toolbox.
Amazon.com: SHANREN LED Work Light Lamp Off Road High Power ATV Jeep 4x4 Tractor 27w 60 Degree Flood Light: Automotive
Those are the lights I used, work great, nice illumination, no issues through high heat and heavy snow and rain. To put one in the predrilled hole on the back of the tractor, I've had to flip the SMV and move the toolbox over an inch. I mounted the lights under the ROPS with U-bolts. All three are wired into the accessary circuit wires that come out of the big bundle that runs right under the SMV. lights, wire, switch, connectors, bolts etc, cost me about $100, well worth it IMO, and cheaper than any kit out there. No blown fuses either:thumbsup: Let me know if you want more details. Sorry, no pics right now.
I don't know what it was with loader, it was on the even concrete floor of the polebarn, and it took a while even with a hammer. It was brand new, so maybe it just needed to loosen up a little, or I hadn't quite got the hang of the controls.
/ New Kioti Owner
Wow thanks for the awesome overview of the light system you set up. I may reach out to you for more detail when I finally get to this project. Right now it's staying light out pretty late so not bugging me enough just yet.
/ New Kioti Owner #27
Thanks for the tips on the hoses. Will definitely try this when the field is ready for cutting.
/ New Kioti Owner
I also watched a few videos of the process first that I feel helped a bit. First below is a Kubota, 2nd a Mahindra, process is effectively the same.
/ New Kioti Owner #29
There is one little bitty problem you can run into IF you take the loader off in the morning when it is cool and then try to put it back on in the heat of the day, pressure will build up in the loader hydraulics. You will have to relieve that pressure before you will be able to get the quick disconnects to connect again. At least I have had that problem when taking off my back hoe, I almost never have the loader off.
/ New Kioti Owner #30
Agree with Gil on the hose pressure building in the daytime heat. One way to avoid same is to hook back to the loader at the very end of the day after letting the tractor cool down to ambient temp. Otherwise, sometimes one may have to use a blunt end punch to tap the inner QD nipple to allow pressure/hyd oil to escape enough to allow the male to plug into the female fitting*. If doing this beware that hyd fluid should not ever enter into/under one's skin, and if for some reason it does seek immediate medical attention.
*Wear gloves and protective eyewear if trying to reduce hyd line pressure, ALWAYS!
Nice rig, BTW, but of course it is- it's a Kioti!:dance1:
/ New Kioti Owner #31
You guys are really tempting me to try taking off my loader. I've been afraid to. I'm sure it will come off easy, I was just worried I would never get it back on. When I am running my haybine or baler it would sure be nice to have it off. I keep the tractor in a garage with a very flat concrete floor, so I think I will give it a try. DSCN1955.JPG
And to Saboism, congrats on your choice/tractor. I have enjoyed mine with no regrets. 50 hours now, just changed the oil yesterday.
/ New Kioti Owner #32
You guys are really tempting me to try taking off my loader. I've been afraid to. I'm sure it will come off easy, I was just worried I would never get it back on. When I am running my haybine or baler it would sure be nice to have it off. I keep the tractor in a garage with a very flat concrete floor, so I think I will give it a try.View attachment 429349
When you get it off successfully and back on, turn around and do it again. Then do it once a week just for fun. The more you do it, the easier it becomes. It is about practice. It quickly becomes so easy it becomes a trivial procedure. I rarely remove my loader on my present tractor, because I just don't have the need to here where I live now. But I used to remove the loaders on previous tractors sometimes several times a week. Moving between loader work and mowing. Give it a try, and you will be wondering why you ever hesitated.
/ New Kioti Owner #33
I think our definition of fun is a lot different.:) But I appreciate your confidence in me. I had this fear of pulling the pins and hearing a tuning fork sound, then the loader sitting in the garage for the rest of my life.:laughing:
I am going to give it a try.
/ New Kioti Owner #34
Well, you don't have to remove and install the loader every week if you don't need to,, but my point was if you do it a bunch of times, you will become adept at doing it, and consider it a trivial job. Of course taking one off in a muddy area, and having it sink unevenly can really be all the "fun" you could ever want.
/ New Kioti Owner #35
My loader is like any other attachment.
If I need it I put it on, if I don't need it I take it off.
Only takes me a few minutes to install or remove.
Mowing is much better with the loader removed. I rarely mow with the loader on.
/ New Kioti Owner #36
Well DK, you and KOua have me convinced. Next chance I get (a day off) I will take the loader off.
I do have one other question about the trans/hyd filter. How to get it off? I guess the factory must assume its permanent the way they tightened it on. Has anyone else had this problem? I do not have a filter wrench yet. (not one of the two I know I have and can not find) So since I'm going to buy yet another one is there a "best" brand or type to get?
When I get my barn built later this year and set up; my wife will not be allowed anywhere near the tool area. She can look all day but no touching! She has a tendency to organize my tools right out of existence. :)
/ New Kioti Owner #37
If your factory Kioti hydraulic filter was easy to take off, it would be the only know one in the universe. I fought with mine for 2 hours.. Recommend a chain wrench, or very large pair of channel locks. Kioti uses a very special gorilla to put on those filters. he is very strong and weighs about 800 lbs.. and he uses gorilla glue too!:laughing:
/ New Kioti Owner #38
I hear ya. In my mind I was inventing new cuss words. The engine filter was also very tight but I had big enough channel locks to get that one. Looks like a chain wrench is in my future. Thanks for your response.
/ New Kioti Owner #39
I don't remember having a big problem with the oil filter, and the hydrostat filter (the horizontal one) was easy too, but Everyone has trouble with the vertical hydraulic filters. I didn't have a chain wrench then, and my largest channel locks were not big enough to go around that big honking filter. I wound up drilling a pilot hole thru it and driving piece of all thread thru it about 3 foot long to use as a prybar. That was after I bought new larger filter wrenchs, that failed. I bought the chain wrench later, after I had it off. I used it on a Kubota though later.:)
/ New Kioti Owner #40
I hope I'm doing the right thing here, but;
To my knowledge, my tractor only has 1 big horizontal hydraulic filter next to the frame. (by the passenger rear tire) Am I not seeing the vertical one or does my tractor only have one?
Michelin Floatbib VF1000-55 R32 Equipment Tires (A64194)
Michelin Floatbib...
2020 GMC AT4 CREW CAB TRUCK (A64280)
2020 GMC AT4 CREW...
2016 Ford F-250 Crew Cab Pickup Truck (A64556)
2016 Ford F-250...
2005 MACK CXN613 6X4 T/A  DAY CAB TRUCK TRACTOR (A67147)
2005 MACK CXN613...
2019 Cadillac XTS Stretch Limousine for Sale, S and S Coachbuilders, 70IN, 7731 Miles (A63689)
2019 Cadillac XTS...
2014 Kobelco SK210LC Hydraulic Excavator (A64553)
2014 Kobelco...
