dodge man
Super Star Member
Its a good looking truck and your son looks like he is doing well. Nothing wrong with spoiling your children, we bought both of our kids their first cars.
Be sure you really want the Flowmaster 40s. I like mine but for the cabin drone at certain RPM, especially when pulling a grade.
Here's my free 2 cents
Anything over 33's with stock gears is gonna be gutless. If he wants to run 35's, you should be looking at 4:11's minimum, 4:56 would be better. you can find on-line calculators for what gears are necessary versus tire diameter to keep a reasonable final gear ratio. If he wants to take it off-road, might even want lower gearing.
Gear Ratio Calculator
12" rim would be ok for 14" wide tires. If he runs 12.50 tires, stick with a narrower rim. Even 10" is a bit wide fore a 12.50 tire, unless he wants curb rash...
Even with just 35's, your going to notice diminished braking. It takes more to slow that larger, heavier mass rotating mass.
You'll need a programmer to correct the speedometer most likely.
It's awesome to build a truck. Done right, it is amazing how much it costs. Tires, rims, lift, gear correction(ring/pinion, maybe lockers). And you aint even made it off road yet![]()
Thanks for your input. This truck will not see much off road action. Hopefully none. We have motorcycles for that. This will be a road queen. He understands the lower torque he will be getting. From a dad's perspective that is fine with me. I thought with the 3.73's we should be fine with up to a 35 inch tire so I would like to hear others opions as well. If churning thick mud I can understand but for a payment pounder....? I used your calculator backwards and with 35 inch tires, his new ratio is 3.42 and 3.63 with 33's. I know they make an inline mph converter for the F250s and will have to check on the F150s. You just clip a wire or two and put it inline under the dash.
Dakota Digital makes (or used to make) one, you tell it that x pulses in should equal y pulses out and it "corrects" the speed.I know they make an inline mph converter for the F250s and will have to check on the F150s. You just clip a wire or two and put it inline under the dash.
