Need help identifying Ford 2000
/ Need help identifying Ford 2000 #1
Homestead Blue
Cleveland, TN
1964 Ford 2000
Hey guys,
I recently inherited a Ford 2000 tractor that I'm going to get running to help me begin to homestead. I am having trouble identifying the tractor based off the serial numbers I'm seeing. I'm most interested in the year, and if it's gas or diesel. Any help you guys can give will be greatly appreciated!
/ Need help identifying Ford 2000 #2
I don't know why, but some pictures posted on this forum I cannot open.
I'm new here, so it may be how I attached it. Here are the numbers:
21201
♢51647♢
/ Need help identifying Ford 2000 #5
You could probably smell inside the fuel tank, but the spark plug check is the best method.
/ Need help identifying Ford 2000 #6
Spark plugs or else... look for an injector pump on the side of the engine block with fuel lines running to the injectors (diesel), as compared to seeing a carburetor sitting on top of an intake manifold (gas).
Thanks so much guys! It definitely has plugs, so I guess gas it is. Now I'd just like to narrow down the date. I found several sites like tractor data that show the codes, but it doesn't make sense based off the numbers I have. Does anyone know the difference between the top and bottom numbers?
/ Need help identifying Ford 2000 #8
Looks like a 1964 model based on the serial number. If you can, post a picture from the side that shows the whole tractor.
Scroll down to the thousand series:
Identifying Old Ford Tractors
/ Need help identifying Ford 2000 #9
The top number decodes the model number. The lower number is the serial number.
Count the number of spark plugs...I'm guessing it will have four, which makes it the earlier thousand series. The later thousand series had three cylinders and a more square shape (totally new design) hood etc. From the pic in your avatar it looks like the earlier series (still good machines BTW).
Here's a side view
/ Need help identifying Ford 2000 #12
Here's a side view
Yep, that's the earlier thousand series, and looks to be very solid, so you've got a great start! There probably isn't a part you can't easily find for that machine (not that they usually need much) and that keeps the prices reasonable. There are some true experts here on the older Fords, so you've come to the right place :thumbsup:
Thanks so much!! I'm very excited to get her running! So far I've got the hood off and started taking off layers of dirt and grease. Next is cleaning up the rats nest of wiring. Have you seen anyone post a schematic for the '64?
/ Need help identifying Ford 2000 #14
I haven't seen one, but it might be worth posting that question in the Ford/NH section here. Generally speaking, it's probably worth your while to buy a shop manual, and parts manual for the tractor. I think you can get the digital version pretty inexpensive now (maybe $20 or less each)....they'll save you a lot of time trying to find part numbers, etc.
I found a manual for the later models, I'll keep looking for mine. In the meantime I found what I think should be very close to a good schematic. I'm going to just go through and run all new wires, it's a mess lol. I attached a screenshot of the schematic, if it looks way wrong let me know.
/ Need help identifying Ford 2000 #16
I can't help on the schematic, but here's a link to a reprint of the factory shop and parts manuals for your tractor. The shop manual is reasonable at $50, but the parts manual is a bit pricey at $115. I think both are worth it, but it might be worth looking for a digital copy...usually those are like $25 and you can print only the pages you need to (if any).
Ford 2000 Service Manual
Ford 2000 Parts Manual
2001 Ferguson 46A Double Drum Roller (A67714)
2001 Ferguson 46A...
2005 Acura RSX Coupe (A64557)
2005 Acura RSX...
2013 C&M TRAILER CHLORINE DIOXIDE MANIFOLD TRAILER (A67714)
2013 C&M TRAILER...
2020 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A66736)
2020 Chevrolet...
2024 BOBCAT S76 R-SERIES SKID STEER (A64279)
2024 BOBCAT S76...
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A67714)
2020 TROXELL...
