Finding V Bolts
   / Finding V Bolts #1
Kodiak45
Gold Member
SC
long 2460 - belarus 250 - JD 4230 - Kioti DK40SE
I need to find some V Bolts for my 3.5" toolbar. I have no idea where to find these things. They cant be that custom of a bolt. Anybody got any ideas? The toolbar is for my allis 74 planters.
   / Finding V Bolts #2
In recent years I've seen more V-blocks and V-straps than V-bolts on toolbars. That way normal bolts can be used.
Like the bottom part on these two clamps. (First photo I found)
Bruce
   / Finding V Bolts
I cant even find the clamps or straps like you showed.. help
   / Finding V Bolts #6
For clamps, I would get some thick wall rectangular tube and cut some out, or have them made. Cut in half, drill, notch.
Or have some V-bolts made, or bend some myself from rod after threading the ends, or maybe use threaded rod.
This is the kind of thing any agricultural area machine shop/welding shop should stock or make as needed.
Or even maybe there is a professional or hobby blacksmith nearby?
Bruce
   / Finding V Bolts #7
The clamps pictured above can also be commonly referred to as T bar clamps (yes, t for tool). They can still be bought from most ag dealerships (although not always a stocked item - these are not as common as they where in the 60's) , as can the bolts you are looking for. They will commonly be referred to as just a U bolt w/ a V bend. Good Luck
   / Finding V Bolts #8
Bruce
Man, that is a neat idea! I'm going to keep that one on my mind because it may be helpful in the future projects I work on.
Thank you Bruce. :D
   / Finding V Bolts #9
You can also google "diamond toolbar clamp" you will get quite a few results.
DRAGON 500 BBL ACID TANK (A58214)
DRAGON 500 BBL...
2018 VOLVO EC480EL EXCAVATOR (A60429)
2018 VOLVO EC480EL...
2019 Allmand Night-Lite V-Series 7 kW S/A Towable Light Tower (A55973)
2019 Allmand...
2014 Ford F-550 (A55973)
2014 Ford F-550...
2017 Ford F-550 4x4 Ext. Cab Mason Dump Truck (A59230)
2017 Ford F-550...
Sprayer Specialties XLRD 1250 Sprayer (A59814)
Sprayer...
