Bush Hog on Front of BX
   / Bush Hog on Front of BX #11
It would likely be cheaper to sell the Kubota and buy a Steiner or Ventrac tractor, which are designed to have the cutter working in front.
Tractors with large rear wheels are designed to PULL. You are working against that basic design principle trying to PUSH a cutter.
It is my OPINION that you would lack traction with so much weight out front. Also, the FEL does not have triangular support which is fundamental to load bearing on the Thee Point Hitch.
Steiner and Ventrac tractors have uniform size wheels and rear engines.
   / Bush Hog on Front of BX #12
It would likely be cheaper to sell the Kubota and buy a Steiner or Ventrac tractor, which are designed to have the cutter working in front. Tractors with large rear wheels are designed to PULL. You are working against that basic design principle trying to PUSH a cutter. Steiner and Ventrac tractors have equal size wheels.
Very astute point, Jeff. But sorta takes the fun out of it. Seriously though, maybe you don't know how much Ron gets out of his BX. I for one, am impressed. He couldn't be without it I reckon.
   / Bush Hog on Front of BX #13
A tractor has a simple beefy axle in the back for varying a lot of weight. Up front you have a small weak, complex axle & expensive to repair axle. Also the large heavy block of iron acting as ballast called an engine is mounted opposite the rear axle. That chunk of iron also blocks your view of what is going on.
You can make a pretty effective argument that the loader is mounted on the wrong end of the tractor in 95% of tractors with them. The only benefit to mounting them there is ease of operation & operator comfort.
Pretty much all the same arguments against mounting a heavy rotary cutter up front. The only benefits would be operator comfort & not running over the grass first.
If you look at commercial mowers that aren't tractors they all have the beefy non- turning axle next to the heavy mowing deck for a reason.
   / Bush Hog on Front of BX #14
Anything that connects to the mid PTO will have its own subframe mounts. If it were mounted to the loader arms and you lifted it there goes your PTO shaft.
I think we figured out why there is no unit that mounts on a BX this way.
   / Bush Hog on Front of BX #15
Agreed 100% that a bush hog on the front very heavy for a BX, would be like driving around with a full FEL bucket. A lighter weight unit would help but then you have to buy a second cutter. An ideal situation is to use the cutter on the rear 3-pt most of the time and put it on the front just for the "edges". You wil have to drive slower, and be more careful. With such an arrangement, a very small tractor becomes extremely versatile in property mgt, landscaping, fire fuels reduction.
Lots of reasons to want it. Doesn't matter how long your tractor lasts if you don't use it to get your work done. A tractor should produce work, if not it''s a garage queen (which is OK too I guess). With the ROPS, there are many situations you just CANNOT access with a rear mounted cutter. If you have a small tractor theres a reason, usually maintaining a smaller plot of land (landscape) and you should then take advantage of your attachments (not allow them to take advantage of you).
Precision brush hogging is strenuous, not just 'uncomfortable', and you end up wiping stuff out that you want to keep. Your front axle can last even longer while you're laid up because looking back caused a crick in your neck. :eek:
   / Bush Hog on Front of BX #16
I've seen 4' brush hogs as low as ~350 lbs, which wouldn't be to hevy, especially since you are removing the bucket. The weight distribution is much further out there though. Would a flail mower work? They are a little more compact, putting the weight closer to the pins.
   / Bush Hog on Front of BX #17
A flail would need to be run "normally", so you would need to flip the gearbox or power it with hydraulics, but it could be done.
Aaron Z
   / Bush Hog on Front of BX #18
I don't know that the weight would be that big of an issue. If using a standard 3-point rotary cutter I would assume you'd put the thing on backwards with the 3-piont towards the QA plate and the wheel out front. The wheel would take a lot of that forward weight. I see two big issues with it though. Turning it, as mentioned would put a good deal of stress on the front hubs and steering mechanism. Also you'd need a 1/2" lexan sheet between you and the mower. Otherwise you'd likely get impaled or bludgeoned by flying debris.
Purpose built front mount QA rotary cutters would likely be designed differently to prevent certain death.
   / Bush Hog on Front of BX #20
Well, look at a Power Trac for example...
428282d1433464753-bush-hog-front-bx-ptpackage-jpg
ALL implements are mounted on the FEL arms out front.... like the brush hog, mowers, buckets, forks, snowplows, blowers, post hole diggers, etc...
All powered implements are powered by hydraulics. No drive shafts.
For the record, the brush hog rides on its own wheels, so the weight is not constantly supported by the FEL or the front axle of the tractor. You just put the FEL in float and push it along in its own wheels. You can lift it up as high as the FEL will raise, but that brings spinning blades of death about head height with the operator, so you may want to limit how high you want to raise it.
Here's a link to a video of a Power Trac PT425 with 48" brush hog VS a rather large multi-flora rose bush. Out front brush hog works well.
PT425MultiFloraRose.WMV
The mount is made so that the deck pivots on the roll and pitch axis independently of the tractor. The FEL in float takes care of the 3rd axis. If you were going to do this on a standard tractor, you'd need something that supplies adequate hydraulic pressure and flow. My PT425 has 8GPM @ 2500psi. Can you get that from a BX25? Can you get that with an added PTO hydraulic pump? It would be interesting, for sure.
Good luck with your project. :thumbsup:
LOAD OUT INFORMATION LOT NUMBER 4 (A53084)
LOAD OUT...
2019 FORD TRANSIT VAN (A52576)
2019 FORD TRANSIT...
John Deere 5100M (A53317)
John Deere 5100M...
2013 Chevrolet Impala Sedan (A55853)
2013 Chevrolet...
2015 Komatsu PC 210 LC (A53317)
2015 Komatsu PC...
UNUSED FUTURE FT 72 PRO 72" HYD MULCHER (A57193)
UNUSED FUTURE FT...
