Zero turn
/ Zero turn #1
buckshot721
Auburn Mi
All John Deere 425 x485 2305 4x2 Gator L130
Ok been thinking of a zero turn for awhile now, been mowing with x485 with a 54" deck. Reason for me is I have both knees replaced and the Doc keeps warning me about kneeling down. (as in putting on a deck). So I'm thinking of just keeping the other tractors for tilling and lawn cart duties, then I have something to just mow with. I have about 5 acres to mow about every 4 to 5 days (and its raining right now). So I'm going with nothing smaller than a 54" deck. Of course its gonna be a JD, any other good reasons to push me over the edge?
/ Zero turn #2
I use a Kubota 72" ZTR and I wouldn't go an inch smaller. I mow 10 acres with it and another four footer and it takes a while. My neighbor has a nice 48" diesel Kubota ztr that he mows 4 acres with and he says it is way too small. He is planning to upgrade to a six footer as soon as he can. I would get as wide a mower as I could.
/ Zero turn #3
Wider is great until you need to get into some tight places, just something to consider. Last year I upgraded to a Dixon Ultra 61 zero turn and love it. The Dixon is rated at 4.5 acres/hr and cut my mow time from 1.5 hrs to 45 min. If you do get a 72" make sure it has a free float deck to prevent scalping. The wide decks can have issues if you have a lot of hills.
/ Zero turn #4
I hate to bust it to you, but there are better mowers than John deer. I have mowers ranging from 42 inch to 72 inch. There are very few places that I can't mow with the big one that the small one will.
/ Zero turn #5
I recently bought a 915B and have enjoyed it a lot! Had a 910A before this and never had a problem with it either. If I didn't run Deere mowers I'd run Exmark or Hustler but that's mainly because dealers are very close by to me and that's what's popular around here.
/ Zero turn #6
There are many good ZTR's today. My choice would be decided if looking, in how many belts does it have. I prefer drive shafts over belts for the drive train and mower decks.
/ Zero turn #7
I went from a Deere 425 with a 60" deck to a Deere 910a with a 54" and could not be happier I cut my now time in half. I went with the 54" because I found it a lot better for trimming around trees and getting into tighter spaces and the zturn mows so much faster smaller deck really was more of an advantage than disadvantage . Also the 54 7iron does such a great job of not scalping on my hills.
/ Zero turn #8
I mow about 7.5 acres weekly. I've had to rear mount mowers, than a belly mower on my 2305 and 2320. When bought my z465 my bellies mower have not been back on since. Mowing is so quicker with the ztr, not by actual ground speed, I guess turning because I'm just done in less time.
As for width, wider is better except for, tight spaces and for scalping on uneven ground. For me and my rough lawn, 72" would work but I'm happy with my 60". 7.5 acres in about 3-3.5 hours. Best part is my son and wife really like mowing with the ztr so rarely get to do it start to finish. I only do Tue slopes.
Last point slopes take time to learn the maneuver. Still today a have a hard time holding a straight line side hilling, and no DWI for this guy. ;) Slopes when wet or moist should be left alone when using a ztr. My opinion anyways.
The other option could be the auto connect deck john Deere has on the 1025r, awesome. My dads picking one up on Monday or Tuesday this week for his property.
/ Zero turn #9
A zero turn is definitely going to cut your mowing time but I wouldn't limit my choices to just a John Deere. There are much better mowers on the market than JD when it comes to ZTR's.
/ Zero turn #10
I use a Deere Z920A...great machine and Deere does make some of the best on the market.
Personally, I'd go for a commercial grade machine, like the 920...especially considering the acreage and frequency of mowing you do. If you want to use a bagger, the Z930 would be a good choice.
If I could afford one, I'd go for the diesel (Yanmar) powered Z997.
/ Zero turn #11
I did my research took a long time to choose which zero turn I would purchase for my place. What I found was that almost all of the various brands available all use the same parts the drives and engines so looking around to find the one that "fits" you and just being one manufacturer specific was a good thing for me. My choices can down to the eXmark pioneer S and the Kubota 200 series. I choose the Kubota for the just massive over build on the frame, shaft drive, hydraulic deck lift system, and the engine is actually built by Kubota.
In my area they were we comparable in price, but in the side by side there was no comparison the pioneer great machine but it was simply a lawn mower but the Kubota was a piece of equipment.
Look around find what fits you ask the dealer for a demo at your place then choose the unit that you liked the best. Happy hunting it can get confusing out there.
/ Zero turn
I have been looking at other mowers, but with the JD dealer only 3 miles away. They always bend over backwards to make sure people are happy with there purchase, plus they will always pickup and deliver for free. The deck on the x485 is 54" and the 425 is only a 48. I love the way the bigger deck cuts, so bigger must be better! The 485 is a brute, rides nice but likes its gas, might trade it in or just sell it out right to cover the new machine.
/ Zero turn #13
...so bigger must be better!
Not necessarily...it will really depend on how flat your mowing area is.
Wider decks will scalp and/or miss areas of an uneven lawn. The width tends to span low areas and scalp high areas.
My Z920 has a 60" which works quite well on my relatively flat 2.5-3.0 acres of lawn. I could probably use a 72" deck, since before I bought the Z920, I was mowing with a 72" Woods RFM without scalping too much. The Z920 is much faster...my mowing time has been reduced by 30% to 40%.
My neighbor has a Z930...and he mows his 4 or so acres of field (as well as his lawn). Although I don't think this is a good idea (commercial grade doesn't mean indestructible...and I use a very heavy duty RFM (set at maximum height) on my part of that field), all he's done, so far, has been to wipe a few blades and, IIRC, one spindle.
/ Zero turn #14
I mowed my 3.5 acres for 6 years with a 2320 and 62D deck. I have about 60 trees to mow around. So 4 years ago I bought a small Toro ZT to mow around trees and obstacles. That worked good and lawn always looked nice. However, this year I added a JD Z665 ZT with 60 inch deck. That cut my mowing time by about 35% and lawn looks just as good if not better. No longer use the 2320 to mow with. I'm very happy with the JD Z665 for looks of cut, speed, comfort and it appears to be well made.
/ Zero turn #15
I have 10 acres and mow approximately 1.5 acres. I chose a 50" Toro with a Kawasaki 23hp motor. I would have bought a Ferris but the price was just about double.
/ Zero turn #16
+1 Roy Jackson. Wider is good if all you have is flat. I have a 60" deck and have scalping problems in ditches. I went from a 42" garden tractor to a Deere ZTR and my mowing time went from 4 1/2 hours to 2 hours. My Deere is a gas engine and I would really like a diesel but the price difference is hefty. As others have said, ExMark, Kubota and Deere all make good machines. If and when I decide to trade in a go to a diesel I would be partial to Deere, but would not rule everything else out until I had done some serious comparison of price and quality.
Good luck
/ Zero turn #17
I have a ZTR with a 50" deck, and a F series Kubota with a 60" deck. I don't notice any real difference in scalping. My old 42" deck Cub Cadet does by far the best job not scalping, but would be painfully slow mowing 5 acres. Unless your yard has lots of hills I would go with a 60" or a 72".
/ Zero turn #18
I personally do not think that Deere's decks do a very nice job in handling material under various conditions. It think they have a great drivetrain. To me if money were no object I would go Grasshopper - front deck for great visibility and ability to get under bushes and shrubs as well as the deck tilting up for cleaning and access. They also are very easy getting on or off, have a very low center of gravity and are extremely stable.
I run a Deines front deck which I bought 17 years ago. It has been nothing short of great. Gator may not like belts but I tightened the deck belts for the first time 3 years ago. they are all original belts and are running well. I use it in all sorts of conditions and it handles them very well - great cut quality as well as great distribution. They are only about 60% of the cost of a Grasshopper.
The things I would never compromise on are a minimum of a 60" deck (72 if your terrain will allow it - I wish had gone 72) and a front deck. There are not many front deck ZTRs made but they are worth it.
/ Zero turn #19
I actually think and have heard professionals say that Deere has one of the best if not THE best decks in the commercial industry. They like it because it performs as well in wet grass as it does it dry grass. They also like that it doesn't clump like some decks and stripes better than most mowers that have striping kits. Now, Deere mowers aren't generally perceived as the best commercial mowers, or even in the top 3 to be honest, but their decks are second to none.
/ Zero turn #20
One of the largest Landscape Businesses around here just bought 25 of the John Deere stand up machines. I'm sure they are fine machines. They had Kawasaki engines. My favorite motor.
UNUSED FUTURE HYD FELLER HEAD (A65055)
UNUSED FUTURE HYD...
T/A CO2 Tanker Trailer (A64194)
T/A CO2 Tanker...
2022 Mack Pinnacle T/A Wet Kit Day Cab Truck Tractor (A64556)
2022 Mack Pinnacle...
2012 Isuzu NPR HD w 5.2L 4HK1-TC Turbo Diesel (A63689)
2012 Isuzu NPR HD...
2021 INTERNATIONAL LT625 8X6 TRI-AXLE TRUCK TRACTOR (A67148)
2021 INTERNATIONAL...
2014 Ford F-150 Pickup Truck (A64556)
2014 Ford F-150...
