Weird error code
/ Weird error code #1
MWILLMONT
I have a JD 3520. The malfunction code is flashing. The code is EENPHI. The first E does not have the top horizontal line , it is not a full E. Does anybody have any ideas. Thanks in advance.
/ Weird error code #2
While bush hogging some property, I got same fault on my 3320. No mention of it in the operation manual and not having any luck searching online. Guess I will wait till Monday to call John Deere.
/ Weird error code #4
Did you ever find out the problem?
Found that code occurred because the gear selector had been bumped into high range while bush hogging the field. Tractor started to overheat. My tractor was being used by my brother in law at the time and he is a big boy and would accidentally bump range selector.
/ Weird error code #5
My scenario was similar. I was cutting the pasture with a lot of dandy lions. The dandy lions seeds were stuck on the screens on the grill. So even though it look like air was flowing through the screens it was not. I washed out the screens, front and back and the problem was solved.
Thanks for your response.
Jay
Skidded Fuel Cell (A67714)
Skidded Fuel Cell...
2017 Ford F-250 Ext. Cab Knapheide Service Truck (A66736)
2017 Ford F-250...
2003 Johnson 60 hp 4-stroke Outboard Boat Motor (A66738)
2003 Johnson 60 hp...
2010 International 4300V TYMCO 500x Regenerative Air Sweeper Truck (A66736)
2010 International...
CAT 953C Cab (A68134)
PALLET OF LIFTING STRAPS (A68842)
PALLET OF LIFTING...
