Weird error code
/ Weird error code #1
MWILLMONT
I have a JD 3520. The malfunction code is flashing. The code is EENPHI. The first E does not have the top horizontal line , it is not a full E. Does anybody have any ideas. Thanks in advance.
/ Weird error code #2
While bush hogging some property, I got same fault on my 3320. No mention of it in the operation manual and not having any luck searching online. Guess I will wait till Monday to call John Deere.
/ Weird error code #4
Did you ever find out the problem?
Found that code occurred because the gear selector had been bumped into high range while bush hogging the field. Tractor started to overheat. My tractor was being used by my brother in law at the time and he is a big boy and would accidentally bump range selector.
/ Weird error code #5
My scenario was similar. I was cutting the pasture with a lot of dandy lions. The dandy lions seeds were stuck on the screens on the grill. So even though it look like air was flowing through the screens it was not. I washed out the screens, front and back and the problem was solved.
Thanks for your response.
Jay
JOHN DEERE 310SL BACKHOE LOADER (A67714)
JOHN DEERE 310SL...
2007 Freightliner M2 106 Pothole Patcher Truck (A66736)
2007 Freightliner...
2015 Autocar Xpeditor T/A New Way 31ASL 31yd Side Loader Garbage Truck (A66736)
2015 Autocar...
PALLET OF FLANGE CUT-OFF VALVES (A68842)
PALLET OF FLANGE...
2027 Terext Light Plant (A67714)
2027 Terext Light...
2004 Mack 613 Concrete Mixing Truck (A64194)
2004 Mack 613...
