PT owners with a flail mower or a brush cutter with the mower blade upgrade?
/ PT owners with a flail mower or a brush cutter with the mower blade upgrade? #1
woodlandfarms
Super Member
Los Angeles / SW Washington
PowerTrac 1850, Kubota RTV x900
Wife and I have been reviewing implements and we keep coming back to trying to get a better cut out in our meadow. at this point my brush hog isn't seeing much heavy duty action, but I am not sure if it is qualified to give grass a good haircut.
All opinions taken.
/ PT owners with a flail mower or a brush cutter with the mower blade upgrade? #2
Can you define "a good haircut"?
All the best, Peter
/ PT owners with a flail mower or a brush cutter with the mower blade upgrade? #4
One major difference between finish and rough-cut mowers is blade speed, especially blade tip speed. Commercial mowers have an even faster blade tip speed than consumer mowers -- you can even hear the difference since they sound more like a turbine....
I'm not sure you can ever get THAT good of a cut from a rough-cut mower because they spin so much slower....
/ PT owners with a flail mower or a brush cutter with the mower blade upgrade? #5
A rough cut mower is just that.
It usually does give a rough cut.
Have you tries thinner blades with a sharp edge.
I have seen rough cut mowers with sharp blades give a creditable cut.
I have the hyd flail mower and it does a real descent job.
They do make rough cut flail blades for heave stuff like 1 in thick stuff.
Have you considered a Zero cut mower like a Dixie Chopper, or a Kubota diesel, etc.
/ PT owners with a flail mower or a brush cutter with the mower blade upgrade? #6
Especially if you are talking about an 2 ft blade spinning at 3600 rpm, the blade tip speed is about 22,608 FPM
Compared to a rough cut mower.
3 cu in motor with 8 GPM = 616 rpm, 4 ft bld
3.14 X 4 X 12.56 X 616 = 7,736 FPM
Year: 2015 Make: Ram Model: 5500 Chassis Vehicle Type: Truck Mileage: Plate: Body Type: 2 Door Cab; (A55852)
Year: 2015 Make...
3ft Metal 5-Point Star Art (A55853)
3ft Metal 5-Point...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
IRTPL LIFT (A58214)
IRTPL LIFT (A58214)
2016 Ford Fusion S Sedan (A59231)
2016 Ford Fusion S...
Giyi KH72 QA 72" 4-in-1 Bucket (A60463)
Giyi KH72 QA 72"...
