Unique Savonius wind turbine
/ Unique Savonius wind turbine #22
Don't want to rain on your parade but there are those pesky laws of physics we all have to follow.
Ever wonder why wind turbine companies install 250ft tall towers and propeller type blades 100+ feet long each ? Cause they are the best performing and lowest cost per Kw hr.
The cup type fill with snow and freezing rain.
No matter what design , the turbine at best makes 1/3 of it's rated capacity because that is all the wind blows.
How many Kw hr do you plan on making with your turbine ? The amount of power depends on swept area . Your turbine would be good for about 50-60 watts in gale force winds.
If the surrounding buildings and trees are 30ft high. The turbine tower should be a minimum of 45ft and 60 ft is better.
Can't argue with any of your comments. I expect to be capable of lighting a few LED's (should I install a little generator). Idea is to check out new concepts. Here's a photo taken a min ago showing how the tower will be situated in the pickup.
/ Unique Savonius wind turbine #25
It is worse than you say. Typical small scale turbine produces about one eighth of rated power in average location. The reason why the turbines are so large there is not a lot of energy in square foot of air stream.
Here's the latest video on the turbine. Working to get it ready for a road test. This video shows making a simple tachometer, modifying the tail braces to make more expansion room for the buckets when they are spinning at high speeds, some tower preparation work, etc. Had the turbine spinning over 500 rpm and am pleased with the results in terms of vibration. With a maximum anticipated tip speed ratio (turbine tip speed to wind speed) of 1.0 will be comfortable operating in 50 km/h winds (about 30 mph) for the initial tests with the pickup.
Made two road tests so far and nothing conclusive re operation yet. Most noticeable was the "tail wagging the turbine" effect. So I increased the size of the two yaw pieces and reduced the wagging somewhat. Yesterday I extended the tail arms and installed aluminum yaw and tilt pieces (original parts were p.t. plywood). I'm hoping this new tail will eliminate the wagging. Will do another road test when road and weather conditions permit. Here's a photo of the latest variation. Just installed 4 C-clamps to the front plate to counteract the extra length of the tail (to control the tilting action). Eventually I will get a video done up showing the road tests.
/ Unique Savonius wind turbine #28
The tail wagging is caused by eddy shedding effect caused either by eddies generated by your pickup cabin or the turbine itself. If it is your truck then you need taller mast and mount it closer to the cabin. If it is the turbine then you can place the the fins on side of the turbine or make them long enough to catch two eddies. One from left and one from right. But I think it is your truck causing it.
https://en.wikipedia.org/wiki/Strouhal_number
https://en.wikipedia.org/wiki/Vortex_shedding
Thanks for the links. Kind of think that the turbine is in a pretty good laminar flow with the current height. Also another possible contributor to the wagging might be the buffeting effect due to the the blunt front plate. Perhaps dumping wind and returning (due to tail influence) to neutral and repeating. Anyway it is interesting and will have a better idea when give this new tail a try.
OK - Just back from a road test and glad to report the wag is gone! Had a GoPro mounted on my chase vehicle but haven't processed the video yet. Now I'm in the clear to work on the augmenter and overspeed control.
Here's my newest video on the Horizontal Savonius Wind Turbine. I have a lot of work done and expect to get another video prepared soon.
/ Unique Savonius wind turbine #32
Cool, keep up the good work! :thumbsup:
Thanks :) Time of year and all doesn't leave a lot of time to play around with video editing but I'm looking forward to getting more info together soon.
/ Unique Savonius wind turbine #34
Nice . Nice video of the ice berg on your site as well . You can see that it has a big crack and is much larger under water .
Thanks - yeah the iceberg video was taken by my grandson with his DJI Inspire drone. He's an excellent pilot and takes the drone places I would not attempt :)
Here's an updated video on the wind turbine (I now call it Savonius horizontal axis wind turbine - SHAWT). The video covers fabrication and the first road tests while mounted on the pickup truck.
https://youtu.be/in9j3iIol_k
Here's my latest video on the Savonius Horizontal Axis Wind Turbine (SHAWT). I got the "tail wagging the turbine" problem fixed (shown in the video) and then I go into doing some testing with the turbine mounted on my pickup. Can't say that I can explain all of the test results - definitely open to hearing comments/suggestions.
https://youtu.be/aKIsgBUM4cU
/ Unique Savonius wind turbine #40
Turbulence is the primary enemy of wind turbines in general. The bigger the more vulnerable are they.
2025 SAWYER 85BP20 20FT T/A ENCLOSED BUMPER PULL TRAILER (A59912)
2025 SAWYER 85BP20...
2015 Isuzu NPR 16ft. Box Truck (A61573)
2015 Isuzu NPR...
2025 Wolverine MCB-11-48W 48in Hydraulic 4-Way Clamshell Bucket Skid Steer Attachment (A61572)
2025 Wolverine...
2019 HYDREMA 922F HM ARTICULATING DUMP TRUCK (A65053)
2019 HYDREMA 922F...
Location Tampa, FL (A61567)
Location Tampa, FL...
2007 MACK CHN613 6X4 T/A DAY CAB TRUCK TRACTOR (A59909)
2007 MACK CHN613...
