IH 674 Hydraulics
/ IH 674 Hydraulics #1
DLTTrekkers
Paarl South Africa
Hi
IH 674 hyaudraulic oil full of air . Lift works for 2 min and then do not whant to lift. When I test the externals oilpressure I do get 16 Mpa/160 Bar but after 2 min it fall to about nothing (air in oil) I did replace the pump , gaskets and o-rings . Also the big o-ring in the groove in the gearboxcasing Please help
/ IH 674 Hydraulics #2
There is an air leak in the suction line somewhere. Find that and you should have the problem solved.
/ IH 674 Hydraulics
Yes. But where ?I checked the big o-ring and the o-ring on the pump and I overfilled the tractor by 20 L of oil .
/ IH 674 Hydraulics #5
Recheck the filter cover to M C V square packing, any imperfection or foreign object in the groove can cause a suction leak. Also check the O ring on
the bolt that secures the filter cover.
/ IH 674 Hydraulics
After checking all of that Iwent ahead and close all the loose pipes aswell and all the air was gone ! The manual do not state that !
Now I have a new problem . My client wants to lift a 1000 l with the rochshaft . Can this tractor do it ?
PALLET OF DISCHARGE HOSES MISC SIZES (A67714)
PALLET OF...
x (A68191)
x (A68191)
Unused 2022 HLA 54in. Hydraulic Root Rake Grapple Attachment (A66734)
Unused 2022 HLA...
340 GAL WATER TANK (A68842)
340 GAL WATER TANK...
Location Tampa, FL. Year: 2017 Make: Dodge Model: Durango Vehicle Type: Multipurpose Vehicle (MPV) (A64557)
Location Tampa...
Unused 2023 Land Pride RCF2060 5ft. Rotary Brush Cutter Tractor Attachment (A66734)
Unused 2023 Land...
