3-Point Hitch 3616 3 point issue
/ 3616 3 point issue #1
bradleycade
Vivian La
Mahindra 3616
I have owned my 3616 for almost 5 years now. I have had several problems out of it, with the most recent being broken stabilizer links for my lift arms on the 3 point. the links broke (both sides) a while back so I rigged up some chains for a temporary fix. I cant see spending over 400 bucks for 2 factory stabilizer links. So, my question is, has anybody else had this problem and went with a different set up? where can I buy/build/piece together my own set of links? I don't really know how to go about doing this so any help is appreciated.
/ 3616 3 point issue #3
Guessing that your anti sway links broke at the first hole while pushing in reverse.? If so, put it back together and weld and grind. It broke because that first hole should not even be there. (very weak point) I put ball swivels on mine. I hate all those movements that they engineered in there. :thumbdown:
/ 3616 3 point issue #4
I have about 11 hours on my new 1538 HST and the stabilizers broke while brush cutting. Picked up a couple of ball joints from TSC today but it looks as though the balls are too wide to fit onto the stabilizer posts on the axle casing. Did you change the pins or narrow the ball to allow the lynch pins to fit?
/ 3616 3 point issue #5
Neither, I drilled and tapped the main pin and have it bolted on. The 4th picture shows that the pin was drilled.
/ 3616 3 point issue #6
Did you drill and tap them while on the tractor or did you remove it from the bracket?
/ 3616 3 point issue #8
I wondered if the factory pins were threaded into the brackets and if they could simply be spun out, stuck in a lathe for drilling and tapping. If they could be removed it may be as easy for me to make new pins that are long enough to be able to use lynch pins.
/ 3616 3 point issue #9
I don't think that they would do that, they appear to be welded in on my 3215.
/ 3616 3 point issue #10
Thank you for the post and pics of your mod to the stabilizers. I have had 3 break and i have only owned my 3616 for a little over a year. I will copy your mod, hope u dont mind. I hate the slack designed into the factory stabilizers also....
/ 3616 3 point issue #11
I agree, I changed mine basically right away. Didn't like what I saw when I first looked at them. Just needed to figure out what to do once I had the machine in front of me and could take things apart.
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
2016 Peterbilt 579 Day Cab w Hydra Flow Setup (A62613)
2016 Peterbilt 579...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59575)
2019 INTERNATIONAL...
2019 CATERPILLAR 262D3 SKID STEER (A62129)
2019 CATERPILLAR...
2008 GMC C7500 CREW CAB FLATBED DUMP TRUCK (A57192)
2008 GMC C7500...
CASE IH MX220 MAGNUM TRACTOR (A57192)
CASE IH MX220...
