What Part Do I Need? CK20
/ What Part Do I Need? CK20 #1
CitizenOfThePlanet
Good afternoon everybody!
So yesterday I made a much needed repair to something on my CK20 and was so pleased to have it working fully again, I hopped on the tractor, and went to shift the gear from low to high, and the gear handle broke right off!
I took off the tractor seat and the panel underneath is and it appears as though the rod completely snapped in half. Does anyone know what this part is called so I can look it up on Michigan Iron? I can't seem to locate it on there. I appreciate your help, enjoy the holiday weekend!
/ What Part Do I Need? CK20 #2
Citizen: Use the "Find Parts by Model" menus to find what you need. The "Quick Parts Search" is rarely successful. I forgot which flavor CK20 you have but this should be close.
Thanks so much! That is the exact part I need and I appreciate your help!
/ What Part Do I Need? CK20 #4
I assume it was part #4 in the diagram that advises to call the dealer for a price. It's probably just common steel and could be welded. Might be worth a try before buying a new one.
Hi Victor,
I thought about trying to weld it but I haven't welded anything since high school shop class. I will absolutely look into it though because it could very easily be welded, I just don't want to do it wrong!
/ What Part Do I Need? CK20 #6
You should be able to have this welded for 1/10 of the price of a new one. Not much to this part.
Eddie
Skid steer Fork Bracket  (A62679)
Skid steer Fork...
2019 John Deere 460E 46 Ton Articulated Dump Truck (A64194)
2019 John Deere...
New 4400lb All Steel Adjustable Gantry Crane (A62679)
New 4400lb All...
2017 Ford Transit 250 Cargo Van (A64556)
2017 Ford Transit...
New/Unused ATS T460 Mini Skidsteer (A65583)
New/Unused ATS...
(4) 17in. Honda Rims (A65640)
(4) 17in. Honda...
