Din Rail Toggle Switch
/ Din Rail Toggle Switch #1
Professor Marvel
Virginia near Culpeper
Ford 5000, Kubota 2150 HST, NH TC45 D, JD 375 Baby Skid Steer --- STUFF THAT GOES ON EM, Schwinn Stingray
Not on tractor topic but everybody here works on all sorts of things so I hoped I could get direction.
I am looking for a supplier for simple din rail mounted toggle or rocker switches for inside a control panel.
Thanks for any help.
/ Din Rail Toggle Switch #2
I think I've seen that in the MSC catalog.
I think their website is:
mscdirect.com
/ Din Rail Toggle Switch #3
You do know how Google works? Just put "DIN rail toggle switch" into the search line. You'll come up with suppliers like Amazon.com, Newark, etc. Really - it's not all that complicated or difficult...
/ Din Rail Toggle Switch #4
Why don't you just use a DIN rail mount circuit breaker as a switch?? You can buy them for less than $10.
The circuit breaker looks like my best choice so far. I will probably end up with that. I was just hoping for a slightly different look for my customer. I didn't think it would be so difficult to find.
thanks
Apparently I have a Google that is far inferior to swines
/ Din Rail Toggle Switch #7
thanks
I use Google Images for this type search.
Found this: https://www.google.com/url?sa=i&rct...DL4P7wSQDDe5bT5JVm3Q-ylg&ust=1431983490655372
425270-din-rail-toggle-switch-31hcur1v0zl-_sx342_-jpg
ended up using a breaker
thanks all
/ Din Rail Toggle Switch #11
yes I had seen this but they wanted something like 65 bucks for it. It's a light switch and i couldn't bring myself to spend that for a light switch. I thought it should be easy to find a switch on a din rail hanger for about 5 bucks. Guess not
Thanks for checking for me
Your'e welcome. I learned what Din Rail is. :D
/ Din Rail Toggle Switch #13
Deutsches Institut für Normung e.V.(DIN; in English, the German Institute for Standardization) is the Germannational organization for standardizationand is the German ISO member body. DIN is a Registered German Association (e.V.) headquartered in Berlin. There are currently around thirty thousand DIN Standards, covering nearly every field of technology.
/ Din Rail Toggle Switch #14
Yes, but do you know what DIN stands for?
I do, I do.:jump::jump: Deutsche Institute for Normalization. Or something pretty close to that....
German institute for standardization in other words.
/ Din Rail Toggle Switch #15
well, heck,, what is the point of asking a trivia question, if you are going to answer it yourself..:shocked:
/ Din Rail Toggle Switch #16
And now I know what DIN is. :D
/ Din Rail Toggle Switch #18
And I bet you thought a DIN was just a big loud noise!:)
Yep, have been in DIN without earplugs! :eek:
But I like din-din. :thumbsup:
2021 JOHN DEERE 331G SKID STEER (A62129)
2021 JOHN DEERE...
2023 Kubota L3560 Compact Utility Tractor with LA805 Front Loader (A63688)
2023 Kubota L3560...
UNUSED 1RMC HIGH END MASSAGE CHAIR (A64281)
UNUSED 1RMC HIGH...
2018 VOLVO VNL TANDEM AXLE DAY CAB (A59912)
2018 VOLVO VNL...
2014 John Deere 310SK 4x4 Extendahoe Loader Backhoe (A61572)
2014 John Deere...
2014 Sullair 185DPQ 100psi Towable Air Compressor (A61572)
2014 Sullair...
